Need Suggestions for new Audio build-list inside thread
Not too hard. I would recommend soldering the top connections and the crossover connections at the main terminal. The most issues Ive had with them is the terminals coming loose. It is a tight fit but can be done, you will have to turn the speaker until it goes all the way in on your choice (Harley or aftermarket) lower pods.
Once soldered, you can bend the terminals slightly and non-forceful. A couple of things to know:
-You wont get a ton of bass (needs to be crossed over @110hz) due to smaller enclosure
-You will get a lot of mid-range and highs
-They will fit in Harley and aftermarket lower pods
-Send at least 145w to them and no more than 270w and you love these.
-Put a DSP on them and they will sound amazing!!
If you are using a DSR1 I have two settings I can screenshot and send you to make them sound amazing!
Hope this helps!!
-Brion
