Newbie Help
Old Aug 31, 2020 | 06:36 PM
Catahoula's Avatar
Catahoula
6th Gear
Default Newbie Help
I have a 2017 Street Glide with a Sony head unit. Unfortunately, the stock Harley 2 ohm speakers were left in. It sounds like garbage and I don't want to damage the head unit with mismatched speakers. I know very little about stereo systems, but I'd like to do a basic amp and front speaker upgrade. I have no intention of adding rear speakers at any time. I don't need the greatest or loudest, just something clear and usable at highway speeds. I'm not sure I want to tackle this myself and may take it to an audio specialist for a new system. However, I could be convinced to do it myself if it's not incredibly difficult. (I am mechanically and electrically inclined) So.....recommendations with a budget of $1000 or so? Thanks!
Old Aug 31, 2020 | 07:13 PM
Mxpilot's Avatar
Mxpilot
I have an AX7000 running front and bag lid speakers with no amp and it’s adequate for my needs, good enough sound, volume, and clarity at 70mph. That said, I know many will disagree, but it’s just my experience.
i did change my own speakers, and I will tell you that the fronts require patience. It is rewarding when they’re done. I would reasonably guess that adding an amp is doable by yourself, my ‘14 has a space for it, and should be available as a plug and play. There’s plenty here that can give better details. I had not done ANY work on mine until I did that, and it works today, so....
Old Aug 31, 2020 | 07:24 PM
Catahoula's Avatar
Catahoula
6th Gear
Thanks. I thought about just changing speakers, but thought that I might as well consider an amp while it was opened up.
Old Aug 31, 2020 | 09:32 PM
FrenchieM's Avatar
FrenchieM
Theres no way a HU will power 4 speakers it will barely power 2 horns. They are probably distorting badly at 70 mph knowing it’s probably cranked. The speakers will be junk in no time. Get an amp
wharfcreek
Audio Systems
45
Aug 9, 2019 10:50 AM
hem1tp
Audio Systems
Jan 25, 2019 10:56 AM
srhen
Audio Systems
Feb 17, 2018 09:08 AM
sbeast
Audio Systems
Jan 25, 2014 06:56 PM
100bagr
May 27, 2012 01:51 PM
