AMP and DSP under Batwing
Old Nov 3, 2020 | 11:04 AM
Chief Silverback's Avatar
Chief Silverback
Default AMP and DSP under Batwing
Hi guys,
I have a quick question.Is it possible to mount a SD EVOX 2400.4 and Daytona 408 DSP side by side above the radio under the Rushmore street glide fairing? Thanks for your help.
Old Nov 3, 2020 | 11:44 AM
travelingypsye's Avatar
travelingypsye
Im running a sony HU, 408 dsp, nvx m4 and 1200.4 in my fairing. Planning on 2 1200.4 soon.
Old Nov 3, 2020 | 03:55 PM
Chief Silverback
No clue you could come close to getting all that in there. So your evo and daytona are side by side running parallel to the HU? From the eyeball test it seems both units would be to long in that configuration.
Old Nov 3, 2020 | 04:59 PM
SBates08's Avatar
SBates08
You also have the BT brackets and no pods if I'm not mistaken.
Old Nov 3, 2020 | 08:07 PM
travelingypsye
I am running the 1200.4 on the amp tray, the 408 under the amp tray in front of the hu and the nvx in the cubby hole clutch side. And yes I have bt brackets.
Old Nov 4, 2020 | 12:13 PM
GunslingersNation1's Avatar
GunslingersNation1
Can you post a pic of that dsp behind the HU. I cant picture that fit.
Old Nov 4, 2020 | 12:17 PM
travelingypsye
I dont have any pics now but will take some when i open it back up. The 408 sits under the stock amp tray butted up against the hu.
Old Nov 4, 2020 | 12:42 PM
Babyboy's Avatar
Babyboy
You can get 3 amps and a DSP in a 14 and up batwing with the stock amp tray and stock headunit.
Amp tray has a 1200.4 evox, 250.2 and a Dayton dsp-408. 800.4evox in the clutch side cubby.
This one has a sony Headunit, JM amp tray
With 3 amps and DD DSI-2 dsp.
JL 600/4 on tray,MMATS 4110 under amp tray,SD250.2 on clutch side bracket and DD DSI-2 in clutch side cubby.
Old Nov 4, 2020 | 12:55 PM
Chief Silverback
Thanks for all of the feed back and pics,. I think I'm going to with this setup, much appreciated.
Old Nov 4, 2020 | 03:05 PM
GunslingersNation1
Ok, here is a pic of mine. Do you experienced guys thing the Dayton will fit in the cubby? Right now its being used to stuff cabling in, but a little tie up work cold fix that. The only issue I can think of is the power side of my EX4 is on the clutch side. Probably not a huge deal with quality rca cables and tusa tape.
