Hi guys I have a Electra glide standard with boom 4.3 and am looking at adding fairing speakers with an amp. Wanting something that I will be able to hear, had the stage 1 boom prior and it was ok but would like louder. Was looking at
Hogtunes REV Series 225 Watt 2-Channel Amp/Speaker Kit
anyone know about it? What are some other options? Budget around $650 if possible
not the route that i would go, more like a pair of Mmats PA 601.4cx or the new Ground Zeros and a Mmats MD4110 amp. bt line levelers or low out converter and go.
m
ps, you might think about changing the head unit, as the one you have doesnt sound good without a lot more stuff, like a DSP
m
thanks looked into those and that sounds like the way to go. As with the other stuff, change out the 4.3? I havent purchased it yet but I was planning to after Christmas. Is it just to old or what is the problem that would happen if I run those speakers with it??
Stay far far away from Hogtunes, J&M, Rockford
GZ coax $250
SD 400.4 S $225ish
BT Line Leveler $90
Amp wire kit $30
You wont be disappointed and far superior to Hogtunes
