I'm sure this has been beat to death but, I just got a 2015 SGS and want to replace the fairing speakers and possible add an amp. What do you guys recommend?
Hey Mike, try adding the amp as well. I went with J&M on the Road Glide and made all the difference in the world. With the exhaust I had it was necessary to hear anything other than noise at highway speed.
**EDIT**
disregard my previous comment. Not sure why I though you were talking about a Roadie.
BT has a 7.1" speaker kit that replaces the entire pod in these fairings. Any good quality speaker is going to need more airflow than can be achieved with that pod in there.
If you want to keep the pods, then take a look at the Kappa 62.11i speakers. You can mount them 1 of 2 ways. Either take the pod apart and mount them from the inside and use your stock grills or mount them on the outside of the pods and change the stock grills to the boom audio grills to give you more depth.
As for amp, sky's the limit here. If I were you, I'd simply replace the speakers first and go from there if you think you need more.
