2019 SGS - help me upgrade from factory to 2 or 4 speakers setup
My total budget would be $600 for everything. I would like to keep the installation simple, with one amp. I am willing to step the budget up a little for possibility of better upgrade.
1. I do not have lowers at this time. I am still trying to decide if I should go with them or not, but if I was, what would be the best speakers for lower fairings? Would it be better to go with better batwing speakers and bridged amp, instead of 4 lower priced speakers? To add: I do not plan on having speakers in the back.
2. What would be the best amp for the buck to power 4 speakers or 2 speakers bridged?
3. What would be the best speakers for the buck to replace the factory ones? I see lots of suggestions for Hertz or MMATS?
4. Where does the amp install on SGS? In the front fairing? If so, can it be installed in the bag instead? I would hate to add weight there.
Thanks in advance for your suggestions.
for $759.20 with spring kick-off discount, including ground shipping to your door, you can purchase a complete kit from J&M with 200w RMS two channel amp and a pair of ROKKER fairing speakers, with tweeters on the grill ,, all plug-n-play and tuned for the stock Harley radio flash ,,,,
PSXK-200SP2-14SG ,,,,
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
An sd800.4 evox amp would run you around 350 to 400 I think...dont quote me. but close.
Bridge those speaker with that amp to get around 250 watts and that will SING with good lows and clear EQ.
If you plan on adding another pair of speakers some time down the road, you might opt for a little more cash up front and spring for the 1200 evox.
Weight from these amps in the fairing isn't an issue. You could install in the bag, but if you're like me...I like my bag space for cloths, rain gear and stuff.
You'll also need to get your HU flashed to flatten the built in EQ curve. Shouldn;t run no more than about 50 bucks.
Then there is misc wiring. You';; need a metra amp power/ground kit to power your amp. I think around 30 bucks maybe, Also run new speaker wires. Pretty cheap to get OFC wiring.
Then you'll need a pac sni-35 to convert speaker level inputs to RCA. And of course a pair of RCA cables. 15 bucks for the pac sni. RCAs are pretty cheap as well.
That set up will get you very loud but very good sound and you may be please with just a 2 speaker system.
Looks like I got some shopping to do. Any suggestions on best places to get this stuff from?
Rokker
Last edited by user 78493; Feb 23, 2021 at 08:31 PM. Reason: Forgot to include link
Rokker
