Two DSP's
Old Feb 24, 2021 | 12:08 PM
teedoff65's Avatar
teedoff65
Originally Posted by SBates08
On both sides of the neck.
Attachment 604374
Thanks. I sent him a pic of the other end. Not sure I took pics of the neck side of the frame.
Old Feb 24, 2021 | 12:23 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
Attachment 604374
Oh so it's that slot in the middle, not the hole below it? That looks real useful.
Old Feb 24, 2021 | 12:37 PM
SBates08's Avatar
SBates08
That's correct. It's actually more of a rectangle when you're looking at it from the front.
Old Feb 24, 2021 | 12:39 PM
Hoyt 1911A1
Thanks. With all the junk I've got in there on my bike it might be a fight to get to it but I think in the long run it'll be worth it. How many and what gauge wires were you able to fit through one side? I think your bike is basically the same as mine.
Old Feb 24, 2021 | 12:43 PM
SBates08's Avatar
SBates08
I have 1-4ga and 1-8ga per side with room to spare.
teedoff65's Avatar
teedoff65
Like i said. It was easier for me to start at the neck side with the rebar. BUT..i have a RG, so the fairing turned to the left all the way made it easier to get to.
I put two 8awg power and ground wires through along with the power and ground wire for the DSP. All through the right side. I assume there is also a hole on the left side of the bike as well, so a ton of wiring can be run through the frame.
Old Feb 24, 2021 | 12:48 PM
Hoyt 1911A1
Thanks y'all that's a big help. I suspect getting the power wires away from the signal carrying ones would help minimize interference, maybe even help FM reception.
I wish we had a repository of organized photos of builds in process we could contribute to. Sometimes when we've got stuff tore apart we don't always think to take pictures, but when we do it could sure help folks get a visual idea of what's possible.
Old Feb 24, 2021 | 12:50 PM
SBates08's Avatar
SBates08
Mine is currently apart as I'm tidying up the last bit of my wiring. I could take some pics for you if you like.
Old Feb 24, 2021 | 01:08 PM
lefty33's Avatar
lefty33
Attachment 604374
I'm assuming then that this relates to all years of touring frames as teed's bike is a Rushmore & Bates has a pre-Rushmore. Can you confirm?
Old Feb 24, 2021 | 01:12 PM
SBates08's Avatar
SBates08
That is correct.
