SD 1200.4 EVOX 5 AWG Power wire?
Old Mar 8, 2021 | 01:48 PM
mrmagloo's Avatar
mrmagloo
Default SD 1200.4 EVOX 5 AWG Power wire?
I'm trying to get all my ducks in a row for my next upgrade, and was just reading the manual and SD suggests a minimum of 5 AWG power wire. Not seeing much in the way of 5 AWG, but is AWG the same as Gauge? And, in the absence of 5 AWG or Gauge, seems I would have to round up to 4 Gauge? Just seems awful thick for a 5 foot run? Just wondering what others are using for this kind of wattage. Lastly, is there a preferred source that carries the wire, inline fuses (60A), Lugs and Ferrules? TIA!!
Old Mar 8, 2021 | 01:54 PM
Flinch's Avatar
Flinch
AWG stands for American Wire Gauge, I can't help with your other audio question, I'm just here to learn myself. I've found some good stuff on other social media for motorcycle audio as well
Old Mar 8, 2021 | 02:09 PM
teedoff65's Avatar
teedoff65
I ran 8awg for my 1200.
Old Mar 8, 2021 | 02:23 PM
mrmagloo's Avatar
mrmagloo
Flinch - Thanks I knew what AWG stood for. Just seemed odd that SD would spec a 5-AWG Size that's not very common. I'm even finding 6 Gauge hard to find.
Teed - Thanks, I'm currently running 8 Gauge with a 40A for my 800.4 so that's good news.
Old Mar 8, 2021 | 02:37 PM
Keggr's Avatar
Keggr
Figure out the amp draw
max current draw on this thing is 113A-116A
Based on following chart - 10GA should be about right at 5 feet, up to 8GA around 6.5 feet, etc
Old Mar 8, 2021 | 03:14 PM
cshocker's Avatar
cshocker
On my 1200.4, I went from 8G cheap wire to 4G OFC, and my bridged undistorted watts went up significantly. 4G is probably a little overkill. But so is most my system, lol. I'd rather have too much than not enough. I order all my supplies from Amazon.
Old Mar 8, 2021 | 03:25 PM
Keggr's Avatar
Keggr
Good point cshocker. I alluded to 8Ga at 6.5 feet, but you have to make sure the wire is high quality to get the proper results. Extra isnt going to hurt anything except your pocket book, and space.
Old Mar 8, 2021 | 03:32 PM
GreenMonster's Avatar
GreenMonster
Maybe. They use 5 awg in Brazil .Thas where SD Is made .
Old Mar 8, 2021 | 03:35 PM
Keggr's Avatar
Keggr
Maybe. I doubt they are using CTA-2015 standards there, so maybe they recommend 5 awg because good OFC stranded wire isnt readily available.......
Old Mar 8, 2021 | 04:28 PM
mrmagloo's Avatar
mrmagloo
Thanks - I was looking for OFC but can only see it at 4 and 8 Gauge. Can't find a single mention of 6 Gauge on Amazon anywhere, which I think would be a good compromise. Plus most of the stuff seems to be Chinese and I think part of the concern is, are you really getting what they advertise? Any reliable vendors?
