SD 1200.4 Gain Issues
Old Mar 23, 2021 | 10:25 PM
MrMetro's Avatar
MrMetro
Default SD 1200.4 Gain Issues
Hey folks,
First here’s what I have:
2018 SGS
Head Unit GT (flashed for 4 speakers, no amp)
GZ Yellow basket 6.5 Coaxial (2 in the fairing and 2 in lowers.
SD 1200.4 4 ohm
RF DSR1 (file from Garage Bagger)
All properly wired from battery, etc
I’ve followed the amp gain adjustments. Head unit 3 steps down from full, 1k pink noise, speakers disconnected at amp. I used a DMM on each channel.
The issue is I can’t get the gain V any higher than 24. I’d like to bring it to almost 29.
Has anyone heard of this or have any suggestions?
Thanks.
Old Mar 23, 2021 | 10:57 PM
SBates08's Avatar
SBates08
You don't use pink noise to set gains. Use a -5db 1000hz test tone.
Old Mar 23, 2021 | 11:40 PM
MrMetro's Avatar
MrMetro
ok. Let me try that. Thanks.
Old Mar 24, 2021 | 08:18 AM
Adenton528's Avatar
Adenton528
Another thing to note is that when doing gains when using a DSP of any kind, the tune should be set to flat across the board for the speakers. It is possible if using a 1K tone, that if the 1K area in the DSP tune is cut or reduced, that the signal from your DSP to your amp is not on full tilt.
Load in a tune that is flat, check master volume on DSP is full, check channel volume is full for the channels you have loaded as your outputs to amp, set gains, then load tune from GBS
Old Mar 24, 2021 | 10:22 AM
teedoff65's Avatar
teedoff65
Thanks for this. I think a lightbulb just went off! lol
I think I might have been setting my gains with a tune already loaded, thought my system still sounds pretty good, I wondered if I was leaving something on the table.
Old Mar 24, 2021 | 11:15 AM
SBates08's Avatar
SBates08
Likely the only time you'll have issues is if you're trying to set the gains for horns or tweeters and the HPF cutoff is above 1000hz. Just went thru that myself. There could be other instances where this could happen but that one would be the most common.
Old Mar 24, 2021 | 11:21 AM
teedoff65's Avatar
teedoff65
I was planning on taking the fairing off this weekend or sometime in the next few days and trying to tweak the tune a bit anyway, since ive got a bit of time on the speakers and a "break in" period.
Old Mar 24, 2021 | 09:19 PM
MrMetro's Avatar
MrMetro
ive read and thought you’re supposed to re check the gains after a new tune is in the DSP? So what your saying is that all speakers EQ should be flat and then tune? I don’t check the gains again after a new tune is uploaded to the dsp?
Old Apr 7, 2021 | 06:55 AM
MrMetro's Avatar
MrMetro
An update to the gain dilemma...
I reset the EQ on my DSR1 to a flat signal (I left the crossovers set and didn't reset those).
I ran -5db 1000 test tone with the speaker wires disconnect (3 steps down from full on the GT head unit).
On the SD 1200.4 I set the first channel to 28.6 V with ease. I went to the next channel and the volts were at 32.7 on the lowest gain. Regardless of turning up the dial the volts barely moved and I could not set the channel.
I then returned to the first one and checked it again (to where It was properly set) and the volts were 6.3. I tried doing it all again and could not set the volts at all to their properly tolerances. I don't understand what is going on.
I finally set them to 'ear' only.
Any suggestions would be helpful.
Old Apr 7, 2021 | 07:44 AM
teedoff65's Avatar
teedoff65
I'm having similar weird gain setting issues. Checking gains and resetting them multiple times only to have a different reading with the DMM each time I check them. I have a thread going for this very issue.....mostly likely a user issue in my case, but I've been conscience of duplicating the steps the exact same way each time when checking or setting gains.
