I am looking at upgrading the speakers and adding an amp to my 2020 Road Glide Special. I had decided on a pair of MMATS 601 cx speakers and Stinger SPX 350X2 amp.
Today I guy I work with offered me a Cerwin-Vega B52 amp for $100. The amp is new never installed. He purchased it and decided to go with a 4 channel instead of a 2.
Does anyone have an experience with the B52 amp? Is it worth getting and installing or should I just go with the Stinger?
If I remember right the only draw back with the b52 is heat. That amp gets hot.
I read these amps get hot somewhere. With the other responses can I assume correctly the heat generated by the B52 amp will not affect other components inside the fairing?
I haven't had any problems with the heat from the amp affecting any components
