best battery?
Old Apr 19, 2021 | 01:41 AM
Big_B_nIndy's Avatar
Big_B_nIndy
Default best battery?
im running about 7500 watts with only 2k going to all bass. what batteries are you guys using?
Old Apr 19, 2021 | 01:44 AM
hamah's Avatar
hamah
Parking lot or with the motor running?
Old Apr 19, 2021 | 01:47 AM
Big_B_nIndy
will probly be alot of parking lots lol and for comps
Old Apr 19, 2021 | 01:52 AM
hamah's Avatar
hamah
what are you running now? Do you have room for aux batteries? (you probably will need them unless the comp is pretty short). Out of curiosity what is your charging system?
Old Apr 19, 2021 | 01:58 AM
Big_B_nIndy
the comps are about a minute and thirty seconds a round i think,iim just now building this bike i dont have a battery yet.i can make a bracket under the fender for another battery. charging system is stock as far as i know on a 03 flhtcui. the bike will be riddin also
Old Apr 19, 2021 | 02:37 AM
JayStronghawk's Avatar
JayStronghawk
With that kind of wattage may be a very good move to have 2 Batteries in Parallel and the highest Amp Charging that will fit might want to check on Police Bike Charging system ..
Old Apr 19, 2021 | 03:52 AM
hamah's Avatar
hamah
Well first off I think you're outside the performance envelope of a single bike battery and stock charging system. A dedicated battery or 2 for your amps is likely called for. Considering the power you want to put out and space/density available on a bike I'd look to lithium vs. AGM. You might also want to consider a bank of caps.
Old Apr 20, 2021 | 01:07 AM
sponger's Avatar
sponger
Either run 2 insane asylum 40ah batteries or 2 of the limitless lithium nano hd batteries. The insane asylum batteries will let you play for longer though.
Old Apr 20, 2021 | 10:34 AM
Adenton528's Avatar
Adenton528
I'm using a Limitless NanoHD under the seat and a Limitless blue 15 aH in pack.
SD 2400
SD800 x 2
SD3000
I get sufficient playing time out of it. Hit me up if you have any questions.
Andy
oakmossy
Nov 20, 2015 07:17 AM
notofthisworld
Dec 5, 2014 11:19 PM
Greabert
Nov 15, 2011 07:02 PM
ShortFatMexican
Feb 16, 2011 04:43 PM
harleybiker
May 9, 2006 12:42 AM
