GTS Upgrade
Old Apr 23, 2021 | 09:02 PM
Ndfastln's Avatar
Ndfastln
Originally Posted by Hoyt 1911A1
The only DSP I have experience with is the Arc, which in my case creates floor noise without the head unit even being plugged into it. Before I added it I had almost no floor noise. From what you are saying I suspect it may just be certain DSPs that do that. It sort of makes sense though, a DSP takes a signal and modifies it then passes it on. I would suspect that modification would add a small amount of noise. I'd like to play with other units but I just don't have the room since I'm keeping all the Ultra functions on a pre-Rushmore ride.
If you are willing, try adjusting the input sensitivity in the PSM. A lower input sensitivity will increase the output voltage to the amps, so you would need to lower the gains accordingly, while raising the input sensitivity will have the opposite effect. I'm curious if lowering it increases floor noise or not. I know the factory HU's have quite a bit of floor noise, so raising the input sens, may lower the HU noise at the expense of increasing it with higher amp gains. It's worth a shot experimenting with it if the noise is bothersome.
Old Apr 23, 2021 | 09:08 PM
teedoff65's Avatar
teedoff65
Ive had this same issue with the arc as well. Might try to mess with the input sens as well.
wharfcreek
Audio Systems
36
Nov 15, 2019 09:53 AM
cprhed
Audio Systems
31
Mar 11, 2019 05:20 PM
INJEKTER
Audio Systems
Aug 1, 2018 09:54 AM
RollieB
Audio Systems
Jan 14, 2014 07:39 AM
