DSP on BikeTronics?
Old May 17, 2021 | 08:33 AM
ddorriety's Avatar
ddorriety
Default DSP on BikeTronics?
Hello,
Currently I am running a 2015 Ultra Limited Low with a Biketronics system, a BT4180.14 amp, BT7P14 speakers up front, Alpine SPR-60's in the tour pack and BT355 LL. My question is would i get a noticeable\worthwhile difference in sound quality if I flash with the "8/2" or the "Rockford Fosgate 2014+ All Bikes" Flash and
pull my BT355 and add A DSP?
If so could I separate the tweeters from the main speakers and feed them from the DSP?
Thanks,
Dennis
Old May 17, 2021 | 09:46 AM
dabears1985's Avatar
dabears1985
I would do whatever flash you choose and see how it sounds. A dsp will give you more tuning ability but you probably don't need to invest the time or money that goes along with a dsp into what you have right now. You would need a separate amp if you wanted to bi amp your coaxials and then control the frequencies of the tweeters with the dsp. If I had your setup I would do the flash and look at upgrading the tour pak speakers to something that was built for running on a bike.
Dan Sherwood
2014-2024 Touring Models
May 2, 2021 04:16 PM
Madd Max
Audio Systems
16
Jul 14, 2020 09:24 PM
hawkijustin
Audio Systems
Mar 20, 2020 10:51 AM
Justind
Audio Systems
Sep 8, 2018 02:41 PM
rickyt'ssnakefarm
Audio Systems
Sep 5, 2018 02:26 PM
