Changed everything from kicker setup…
Old Jun 11, 2021 | 10:16 PM
billindelicato's Avatar
billindelicato
Default Changed everything from kicker setup…
So after a few days waiting for back orders to come in I went and changed everything… ordered 3 sets of gz yb 6.5 and a set of db drive 6x9 along with 2 sd 800.4 amps… so I’m left with a couple questions… and yes I have a dsp to go along with everything already on my bench…
1. can I bridge the 4 in front to 2 channels on the amp? Along with 4 in rear to 2 channels on the second amp?
2. will the gz yb 6.5 speakers fit in the hogtunes lower pods (2015 Ultra Limited with wet heads)?
Old Jun 11, 2021 | 11:21 PM
Tailwind's Avatar
Tailwind
EVO X Amos correct?
You have 8 speakers and 8 channels available right?
All 4 ohm speakers?
If all of the above is correct, ur essentially stuck wiring them straight up to each speaker without bridging.
T
Old Jun 11, 2021 | 11:25 PM
billindelicato
Originally Posted by Tailwind
EVO X Amos correct?
All 4 ohm speakers?
T
yes 8 speakers all 4 ohms… my concern with that is will I have enough to power all 8
Old Jun 11, 2021 | 11:38 PM
Tailwind's Avatar
Tailwind
Based on the 800.4 EVO X ur gonna get each speaker 147 watts at 14.4 volts. A lil light for the GZs but if ur already pregnant with those supplies u have to run what u brung.
Two 1200.4 2 ohm would have been a better play. U could have bridged & paralleled off of those and gotten each speaker 300+ each.
It is what it is.
T
Old Jun 11, 2021 | 11:47 PM
billindelicato
It is what it is.
T
i couldn’t pass up the price of the 800.4s… I’m not trying to achieve super loud just super clean
Old Jun 12, 2021 | 07:52 AM
Tailwind's Avatar
Tailwind
I totally get it brother. Run what you have and see how u like the results.
But just remember that u cannot bridge & parallel the 4 ohm amp in an attempt to puff up the watts a bit thus ur pretty much stuck with straight up traditional wiring of ur 8 speakers to 8 channels.
T
Old Jun 12, 2021 | 08:01 AM
billindelicato
T
I have zero problem running it 8/8 especially with the dsp I just don’t want to under power them and have them sound horrible… I’ve spent way too money already chasing this dragon…
Old Jun 12, 2021 | 08:33 AM
Tailwind's Avatar
Tailwind
I wouldn't say ur technically under powering the speakers but you are gonna be leaving a lot of potential on the table.
Above 50 mph u will be kicking urself.
T
Old Jun 12, 2021 | 09:38 AM
SBates08's Avatar
SBates08
These are the type things you have to take into consideration when buying components for your system. Yes price becomes a factor but if the deal is not best suited for your needs, deal or not you've wasted those dollars.
MikieB
Audio Systems
May 23, 2021 10:30 AM
jaodnam89
Audio Systems
Jul 22, 2020 02:34 PM
Delzore
Audio Systems
May 21, 2019 09:29 PM
refg3880
Audio Systems
14
Sep 24, 2016 09:38 AM
gsparesa
Jan 14, 2006 02:01 PM
