Voice Commands not working
Old Jul 21, 2021 | 02:35 PM
smittyp83's Avatar
smittyp83
Default Voice Commands not working
Tried doing a forum search but couldn't find anything
On my 2017 Ultra Limited, the voice recognition commands for the radio / phone are no longer recognizing the basic commands like "tune to satellite channel xxx" or "Call Home". I'll either get the voice prompt back like "Pardon?", telling me to give a new command or it will change the radio to some random AM station.
Any idea what this could be or tips how to fix it?
Old Jul 21, 2021 | 02:42 PM
TriGeezer's Avatar
TriGeezer
Weird that this has happened to me intermittently recently. I know the left switch pack works, and the can bus is working, because all the other functions work. But, if I turn off the bike for a few minutes it comes back. I wonder if the contacts need cleaned for the voice command switch? There was another thread, that I can’t find, where someone took the pack apart and the contacts were corroded. It didn’t look that difficult to do.
sailmotion's Avatar
sailmotion
If you are using the hardwired system, first thing I would check is that the plug has not become partially dislodged from your helmet or the bike.
Old Jul 21, 2021 | 02:45 PM
TriGeezer's Avatar
TriGeezer
Thsts shouldn’t matter. Because when you push the button, and hold it for a while, with the phone connected by Bluetooth, then you should invoke Siri…and that didn’t happen with mine.
Old Jul 21, 2021 | 03:02 PM
smittyp83's Avatar
smittyp83
The plugs are in good shape and everything else with the headsets work, so I know that's not the problem. Also, I can activate SIRI on my iphone with the comm button.
I think I'm going to do the factory reset on the radio and see if that does the trick
Old Jul 21, 2021 | 03:05 PM
TriGeezer's Avatar
TriGeezer
Well…that’s weird. Sounds like a software glitch.
Old Jul 22, 2021 | 01:29 PM
smittyp83's Avatar
smittyp83
Not sure what you mean - SIRI is supposed to work through the comm system.
SeniorChief56
May 25, 2014 07:54 AM
freenez
Audio Systems
Apr 15, 2013 12:14 PM
reelly1
Audio Systems
May 22, 2012 07:04 PM
gsxrboy96
Jan 19, 2010 08:47 PM
