Need help with audio setup please
Old Jul 24, 2021 | 08:02 AM
Mvan1997's Avatar
Mvan1997
Stage III
Default Need help with audio setup please
I have a 2016 Roadglide
I am running a 4 speaker setup
2 diamond audio 6x9s in the bags and 2 audio legion mr6n coaxial 6.5 in the front fairing. I am running a
soundigital I believe 800 watt evox 4 ohm amp to power all 4 speakers and horns as well as a line in converter to clear distortion
Last month I rode in the rain after picking the bike up. The next few days my speakers started to cut out yea yeah the front left completely went out so I took them out and sent them back to get fixed. I ordered a brand new set because I am impatient. I installed them fine the speakers were playing awesome and then out of nowhere they started cutting out again. But only the front speakers. What’s confusing me is the back speakers play fine even when the fronts are cutting out and distorting. I tried switching channels on the amp and it’s still only the front doing it.
correct me if I’m wrong but would that mean the amp is fine it is either the head unit or the wiring to the front speakers? I’m lost and tired of messing with this
Old Jul 24, 2021 | 09:00 AM
mcdc1224's Avatar
mcdc1224
Is the amp wired as bridged or ?. What flash are you running? How are the crossovers set. If I remember correctly the legion's are rated at 300 RMS and the diamonds are 125 RMS
Old Jul 24, 2021 | 01:33 PM
teedoff65's Avatar
teedoff65
Switched channels on the amp. What does that mean exactly? Did you switch the front speakers to the rea channel and rear speakers to the front?
Old Jul 24, 2021 | 03:25 PM
Mvan1997's Avatar
Mvan1997
Stage III
fronts are Bridged rears are bridged
Old Jul 24, 2021 | 03:26 PM
Mvan1997's Avatar
Mvan1997
Stage III
correct that’s what I did
Old Jul 24, 2021 | 03:35 PM
Dsm Limited's Avatar
Dsm Limited
Now that you switched front and rear amp output channels, try switching the rca input cables to see if the problem moves.
Old Jul 24, 2021 | 03:49 PM
madhunter60's Avatar
madhunter60
The sd 800.4 evox amp is 4ohm stable bridged what ohm speakers are you running?
Flip flop your rca's from the line converters to see if it stays the aame.
Old Jul 25, 2021 | 02:07 PM
kloccwork419's Avatar
kloccwork419
Sounds like wiring to me. Could be as simple as your amp jacks being loose to the channel on the amp going bad. Also could be the output on the stereo for that channel. Switch the jacks around from front to back and see if its still doing it. Could have vibrated loose or pinched somewhere
Old Jul 27, 2021 | 01:57 AM
qclassic's Avatar
qclassic
It's the HP/FULL/LP switch I had to spray contact circuit board cleaner in the switch and the amp is brand new.
traveler
Audio Systems
Aug 31, 2018 03:37 AM
TANK'S 250
Audio Systems
Jun 27, 2012 08:56 AM
