Gzcf 6.5 spl
Old Aug 12, 2021 | 11:54 AM
mcdc1224's Avatar
mcdc1224
Have had several SD's dead on arrival on the output side earlier this year, but nothing else, and no cutting out.....have not cut the coil on any. As Adenton noted, would be good to know how the DSR was setup for them on the EQ side
Old Aug 12, 2021 | 12:00 PM
SBates08's Avatar
SBates08
Originally Posted by KATD
have the stock HU 2016 Ultra
Have the gain set at minimal
have the crossovers set at 80hz thru the dsp with 12db/oct...recommended setting for GZ
How many watts were you sending them? Voltage readings when setting gains?
Old Aug 12, 2021 | 12:06 PM
KATD's Avatar
KATD
125 watts at 19 volts gain setting
Old Aug 12, 2021 | 12:08 PM
teedoff65's Avatar
teedoff65
Out of curiosity, have you eliminated the DSP from the mix when using the SD amps?
Old Aug 12, 2021 | 12:21 PM
Adenton528's Avatar
Adenton528
19 Volts at a 4 ohm load is 90 watts.
It looks like you may be running the Y harness that taps into radio harness and goes to DSR1. Has your radio been flashed at all? If so, what is it set to?
Also need to hear about crossovers and maybe see a screenshot of eq on those speakers.
Old Aug 12, 2021 | 01:18 PM
mrmagloo's Avatar
mrmagloo
i did..7.1 pros and not a problem...hook up the GZ and cut out on volume
I think I'm gonna sell the 2 SD800.4 @ a loss and buy another BT amp and still use the BT418p.
i love the speakers and they do sound great with the BT amp.
I'd highly recommend putting that thought on hold. You have in this thread a number of legit experts that can help you to walk through the troubleshooting and solve this, if you take the time to provide the detailed answers they are asking.
My .02 fwiw.
Old Aug 12, 2021 | 02:20 PM
Tailwind's Avatar
Tailwind
My .02 fwiw.
I too predict that the odds of it being a minor setup issue is about 80/20.
Be patient brother. DSP Input settings, DSP output, crossovers, EQ, and Vac at amp output are a good place to start.
T
Old Aug 12, 2021 | 04:11 PM
teedoff65's Avatar
teedoff65
My .02 fwiw.
T
Now hold on a second guys....
OP how much of a loss are you thinking??
Old Aug 13, 2021 | 04:44 AM
mcdc1224's Avatar
mcdc1224
OP, Good advise given above. f you have two 800's feeding 4 GZ's, you should be up around 32 volts bridged on 4 ohm's. I misunderstood and thought you were running a single 800 on 4 GZ's..
Old Aug 13, 2021 | 04:46 AM
mcdc1224's Avatar
mcdc1224
My bad.....yea how much
