Rockford Flash
Old Aug 17, 2021 | 12:39 PM
Dgull48's Avatar
Dgull48
6th Gear
Default Rockford Flash
Was trying to verify my headunit was flashed with the correct EQ version for the rockford system I had installed(HD14U). It shows Version 1.1.0 for eq but the stereo sounds like crap. The stock speakers with no amp was better overall. I corrected the amp gains, dealer must of let a three year old set this one, and it's a little better but still high heavy and nothing on the low/mid end.
Old Aug 17, 2021 | 08:48 PM
chopper_man's Avatar
chopper_man
What's your setup? HPF settings? Gains voltage? Did you confirm which flash it's running?
Old Aug 18, 2021 | 06:48 AM
Dgull48's Avatar
Dgull48
6th Gear
HPF set to 75, front and rear gains are at about 1130(did not verify voltage) treble/bass boosts left all the way down. Basically exactly as the rockford instructions specify. Unsure about the flash, thats why I asked here. I was hoping someone with a 2021 that has the flash could verify the EQ version. I'll probably just take it to a shop locally for the 8/2 TR flash since it's relatively cheap.
Old Aug 18, 2021 | 08:36 AM
mcdc1224's Avatar
mcdc1224
The 8/2 will be the flattest, and will be the closest between run and acc voltage
Bunker
Audio Systems
Jul 18, 2021 10:09 PM
MikieB
Audio Systems
May 23, 2021 10:30 AM
wharfcreek
Audio Systems
Oct 28, 2019 10:52 PM
Scooby1426
Audio Systems
34
Oct 23, 2017 05:47 PM
Street_Glyding
Audio Systems
13
Jun 9, 2014 09:07 PM
