Fader not function properly......
Old Sep 5, 2021 | 06:04 PM
golfblues's Avatar
golfblues
Default Fader not function properly......
19 SG...ARC moto720 4 channel amp, Arc CX6 fairing speakers and Mmats 690's in the lids.
Techno Research RF flash.
GTX radio connected to amp via channel 1 and 2 input.
The problem...
Fader centered all speakers play fine at all volumes. Fade to front and nothing changes.
As I fade to rear and all 4 speakers go lower in volume together once it is left of center and all shut off in full rear fade.
The fader acts actually acts like a volume control from Full rear Fade to Center and does nothing from Center to front.
Any ideas?
Old Sep 5, 2021 | 06:38 PM
hamah's Avatar
hamah
So you only have 2 channels connected at the input (ch 1 and 2)? You won't get fade unless you have 4 channels connected from the HU to the amp. You'd also need to be flashed for 4 speakers and have the amp input select set to 4CH. I'm not sure if the RF flash has a 4 speaker flash or not (I think their's might be 2 speakers) but you could test with the Harley 0 amp/4 speaker flash if not.
I know a lot of people don't worry about having rear fade and are fine with 2 channel input and 4 speakers output from the amp. Personally, I like to have fade.
Old Sep 5, 2021 | 07:01 PM
golfblues's Avatar
golfblues
Originally Posted by hamah
Sounds like it was flashed for 2 speakers so there would be no fade. Is there a 4 speaker flash you could use? Not sure if RF has one but you could try the Harley 0 amps and 4 speaker flash to confirm everything else. Lots of people don't bother with fade but I like it myself.
I don't think there was a choice for two or four speakers with the RF flash. As I understand it is that flash should have fade control. It's not the end of the world for me but just wanted to confirm with others that have the RF flash. Maybe its the connection from the GTS to the amp using only the 2 channel inputs.
Old Sep 5, 2021 | 07:39 PM
hamah's Avatar
hamah
Smile
I changed my reply but you caught the original . You'd need 4 channels from the HU to the amp to get fade control. It does sound like you have fade enabled as I don't think you'd be able to adjust the setting otherwise.
Old Sep 5, 2021 | 08:08 PM
golfblues's Avatar
golfblues
I think you are correct....I wonder if there is another connector empty in the head unit harness to use channels 3&4... if there is I would need another patch cord to go to the amp if that is an option. If not I will just leave it as is. Thanks
Looking in Ronnie's Parts finder bikes with front speakers don't seem to have rear speaker connections in the harness.
Old Sep 6, 2021 | 02:01 PM
hamah's Avatar
hamah
If the wiring in your '19 FLHX is the same as the '15, and I think it is, there is a 6 pin (gray?) Molex MX150 connector for rear speakers. Unless the bike came with speakers in the saddlebags it should be not used and capped and sits above the radio. The connector is labeled 162 Rear Audio in the manual (not sure if it's labeled in the wiring harness).
The pinout is:
Rear Left + pin 1
Rear Left - pin 2
Rear Right + pin 3
Rear Right - pin 4
Not sure how you have your front speaker outputs connected to your amp but that should give you enough info to repeat for the rears.
Good luck!
Old Sep 6, 2021 | 02:12 PM
golfblues's Avatar
golfblues
If the wiring in your '19 FLHX is the same as the '15, and I think it is, there is a 6 pin (gray?) Molex MX150 connector for rear speakers. It should be not used and capped and sits above the radio. The connector is labeled 162 Rear Audio in the manual (not sure if it's labeled in the wiring harness).
The pinout is:
Rear Left + pin 1
Rear Left - pin 2
Rear Right + pin 3
Rear Right - pin 4
Good luck!
I just had the front fairing off about two hours ago to adjust the gains and buttoned it all back up. Next time I'm in I will take a look for that but I'm not so sure that it's the same on the 19 with the GTX radio.
thanks for the heads up
Old Sep 6, 2021 | 04:21 PM
rblahetka's Avatar
rblahetka
There is another connector near the radio for the rear channels. You can either cut it and wire to that, or order one of these and connect that way:
https://vtwinaudio.com/product/v-twi...g-kit-3-2-2-2/
Old Sep 6, 2021 | 04:30 PM
golfblues's Avatar
golfblues
That looks good... I'm going to give ARC Audio a call tomorrow and see if they have a connector pre-wired with the right connector going into the amp
Old Sep 21, 2021 | 10:15 AM
golfblues's Avatar
golfblues
Thanks to all for the help. I was able to get the connector for the bike rear speakers from vtwin audio and the amp input connector from arc and spice them together and now everything works as planned with total fade control.. it makes it easier to dial in the front and rear speakers separately. It sounds great.....thanks again.... And yes I did reset my gains and crossovers and switched to 4 channel input.
Eric Steward
Audio Systems
14
Dec 13, 2019 03:56 PM
3/4 life crisis
Jun 19, 2016 07:26 PM
3/4 life crisis
Sep 9, 2009 10:49 PM
bigskyhd
Aug 17, 2009 02:39 PM
rideshack
Vendor For Sale Classifieds
11
Aug 10, 2009 11:08 AM
