On the stinger amp it states a 3 channel mode.
I'm try to bridge my rear speakers 8 ohm, but they are sounding like a toy radio. So, what should I be connected too?
Mine is wired the same way. I called stinger up to clarify what wires to use in the pigtail.
Might want to call them up to verify you have them wired up correctly.
just got off the phone with them. They said it was correct.
These are the wires I'm using, is there a Dsp involved if so is your amp set to flat? And switch in 4ch mode? Polarity of individual speakers wired together properly? Input source correct at amp. Just throwing thoughts out not trying to be a smart a##. Good luck? I didn't have much luck with stingers service department, they didn't even know their instruction sheet and back of the amp didn't match when I called for help.
