SD GZ Setup Help
I have them connected to all four channels separately and the volume is underwhelming. How are you guys running these GZ’s ?
Gain voltage? Crossover, HP or Band and where to start? Thanks for any help you can offer.
Ken - In theory, you could try it, however I have never tried it with dissimilar speakers so I hesitate to comment. Perhaps there are others out there who have tried this successfully (or not) who can chime in. Seeing you don't have to change much to test it, I would give it a try and proceed cautiously. My one concern would be the high cut to accommodate the GZ's might be too high for the SPL's. I've never ran the SPL so I'm not real sure of the best settings with these guys.
I ran into the same scenario with my last build with a SD800.4 4-Ohm, and during my upgrade this time, determined that the 2-Ohm provided a better solution for my needs, and of course I wanted more power. Eventually I'll be running the rears off the SD800 bridged at 400w ea, if I don't bump to a SD2400
My .02 fwiw.
My .02 fwiw.
Now perhaps he's incorrectly reading how many watts he's pushing them? I know when I did my bike, I set gains where I thought was one number, but when I went back it was a different reading. Had to do with the gain pots on the pac I was using. I have those all the way open now and didnt need to even crack my amp gains at all to get my desired wattage.
