Amps
Old Oct 27, 2021 | 04:11 PM
Dsm Limited's Avatar
Dsm Limited
Originally Posted by hamah
This is another one of those controversial topics that is continuously debated and open to wide interpretation.
This topic surely shouldn't be controversial, continuously debated or open to interpretation. This isn't a subjective comparison like, what's the best speaker.
For example...When you side by side test amps rated at 175w per channel and amp 1 outputs 190w but has horrible wave patterns on the O scope starting at 135w, I'm not impressed.
Now check amp 2, it outputs right at rated power of 175w and retains a clean wave pattern all the way, that's the amp I want.
Can you hear the difference at 65mph, maybe not. But I can absolutely hear the difference while static or low speed.
Old Oct 28, 2021 | 07:11 PM
D1127's Avatar
D1127
Originally Posted by Fireball Jack;[url=tel:20253857
20253857[/url]]A lot of old school guys still use Tube Amps. Peavy has started making them again and I am sure Ted Nugent uses a tube amp. A solid state amp just doesn't have that crunch.
Have to agree. Marshall JCM800 100w 2203 one of the greatest of all time. Mesa-Boogie MkII, and some plexi’s as well. But, pretty sure Dimebag Darrell used solid state stuff so......... still love tubes!
Old Oct 28, 2021 | 11:24 PM
Bluesman280's Avatar
Bluesman280
I have a basement full of amps, including Marshalls, Peavey's, Traynors, Mesas, etc.... all tube.
I also have a few solidstate amps. Very few solidstate amps will hold their own, tone wise to a tube amp. That being said, not all tube amps are created equal either.
Marshall JCM 800 2203....awesome!
Fender Hot Rod Deluxe....not so awesome, much better after being modded.
Peavey Classic 30 & 50's awesome.
Peavey Ultras....great rock sound!
Peavey Bravos...Awesome tone at lower volumes, but only 25 watts and not quite enough jam for stage use.
Traynor YBA 1's shear power, great tone.
Peavey transtube head, not bad for a solidstate.
Crate Excaliber, great sounding rock head, solid state.
​​​​​​Most other Solidstate Crate amps are terrible.
Roland cube, modeling amps, decent tone for solidstate amps.
There is definately differences in tone, warmth, harshness, in different amps.
The same goes for home audio amps. A Nikko power amp has a very unique tone compared to a Kenwood.
Same goes for Rotel, Adcom, Bryston, Hafler, Yamaha, Carven, NAD, although subtle changes are not always obvious, a better bass response and warmth can be heard in certain amps.
I know not everyone will agree there are differences between all amps, but there are certain amps that will stand out, even in blind tests.
Even on a motorcycle, I have noticed different tone characteristics between amps. Although it may be partially due to different wattages, the tonal difference was definately obvious between a Stinger and a Massive TX48 I have used on my old bike.
Stinger was definately warmer sounding with Mmats at 100 watts, vs The TX48 at 140 watts, which sound harsher, even at lower volume.
Old Oct 29, 2021 | 05:09 AM
Dsm Limited
I'll say it....
JL makes the cleanest, warmest amp I've ever heard and tested. They may not be the most powerful amp and don't work in all setups, but if 150-175w is your target, it's the *****.
I've tested, used and heard almost all the amps recommended for bikes on this forum and FB. Some amps just work better for certain applications.
Old Oct 29, 2021 | 05:47 AM
D1127's Avatar
D1127
“..Basement full of amps..” my hero! I have a little collection myself.
Correct me if I’m wrong, but with tube amps you really have to get those tubes glowing ( hot, warmed up, whatever you want to call it ). They have to run. That’s when you get those characteristics of what they can offer. Can’t baby them, you won’t get a true idea of what you have. I think the same is true of some of the amps mentioned here that we all use. Have to run them, smart and safe of course...
Scooby1426
Audio Systems
May 13, 2014 12:43 AM
Overdoo
Mar 6, 2014 10:03 AM
andyp
Apr 10, 2010 10:30 AM
parrothead306
Jun 20, 2008 09:51 AM
brianseay
May 28, 2007 10:01 AM
