stinger 700.4 amp
Old Feb 16, 2022 | 03:29 PM
softail7316's Avatar
softail7316
Great thanks for the help.
Old Feb 16, 2022 | 03:34 PM
travelingypsye's Avatar
travelingypsye
Just what speakers are you going to bridge off that amp?
Old Feb 16, 2022 | 03:38 PM
softail7316
Ground Zero yellow basket i also have a set of Hertz Mille pro coax from old street glide
Old Feb 16, 2022 | 03:41 PM
softail7316
Will use which ever sounds better
Old Feb 16, 2022 | 03:51 PM
softail7316
Thanks for the help.I assume if i bridge the amp the config switch should be set from 2 channel to 4?
Old Feb 16, 2022 | 03:53 PM
softail7316
Sorry for the last question from previous response i should keep switch at 2 channel
Old Feb 16, 2022 | 04:06 PM
travelingypsye
If bridging it, and only running the GZ's you can use 2 channel input. Be careful when setting the gains in bridge mode as those gz's wont take 350w for a long period of time. You will need to set the gains on the amp to give around 250w and that will make those GZ's sing. Any more power than that will make them harsh and have the potential of seeing that blue smoke no one wants to see.
golfblues's Avatar
golfblues
2 channel
Old Feb 16, 2022 | 04:17 PM
softail7316
Well on specs says 350rms X1 @4 ohms.So i think bridged would be 175x2 @ 4ohms be nice if they specs were correct
Old Feb 16, 2022 | 04:27 PM
travelingypsye
You have got that ALL WRONG!!!
When bridging that amp, you will get 350w per channel. Not 175. If you read the spec sheet, it states that the output is 125w each channel running 4 ohm speakers and 175w each channel running 2 ohm speakers.
350w on each channel when bridged running 4 ohm. That is what you will be getting running the gz's bridged.
