stinger 700.4 amp
Old Feb 15, 2022 | 03:54 PM
softail7316's Avatar
softail7316
Default stinger 700.4 amp
Hi,Was looking at the specs of this amp and states 350x2 at 4 Ohm 175x4 at 2 Ohm 125x4 at 4 Ohm.I cant see how you would wire it to get 350x2@4 ohms?
Old Feb 15, 2022 | 06:59 PM
Fireball Jack's Avatar
Fireball Jack
Channel 1-2 are bridged and 3-4 are also. Making it 2 channels. Positive of channel 1 and negative of 2, 3-4 do the same.
Old Feb 15, 2022 | 07:13 PM
softail7316
Hi I only see a switch channel 2 or 4 i do not see seperate channels 1,2,3,4
Old Feb 15, 2022 | 08:43 PM
hamah's Avatar
hamah
Are you referring to the SPX700X4? Are you sure it'll do 350X2 at 4 ohms? I see in the specs 350x1 @ 4 ohms. Anyway the description on their website says they do but the specs in the manual say they don't. One of them is incorrect.
The outputs are labeled front left and right, rear left and right (4 channels, AKA channels 1,2,3,4). The switch is if you are using 2 or 4 channels on the inputs and has nothing to do with bridging. So to translate for Fireball, one of your bridged channels will be RL- and RR+, the 2nd channel will be FL- and FR+. This is labeled on the faceplate of the amp and shown in the instructions. (it does show 2 channels bridged in the diagram so maybe the specs are wrong).
Old Feb 15, 2022 | 09:42 PM
softail7316
Not really sure but under features it says?But in manual no where does it show wiring for 350x2 4 ohms
  • Target Voltage: 8-16 Volts
  • 350x2 at 4 Ohm 175x4 at 2 Ohm 125x4 at 4 Ohm
  • 3CH MODE: 350x1 at 4 Ohm + 175x2 at 2 Ohm or 125x2 at 4 Ohm
Old Feb 16, 2022 | 08:31 AM
golfblues's Avatar
golfblues
Bridged, 4 ohms: 350 watts x 1 chan
By the printed specs I would think bridged x 2 channel 4 ohm speakers=175 watts each
Old Feb 16, 2022 | 09:31 AM
teedoff65's Avatar
teedoff65
So lets back up here a minute. What speakers are you trying to run? You're worried about bridging specs before even telling anyone which speakers you're going to use.
Old Feb 16, 2022 | 11:44 AM
softail7316
Thanks for the help from reading you cant bridge for 2 channel@4 ohms
Old Feb 16, 2022 | 01:44 PM
teedoff65's Avatar
teedoff65
Confirmed with some guys that know.
The manual is a typo. You can bridge both front and rear channels.
Old Feb 16, 2022 | 01:46 PM
travelingypsye's Avatar
travelingypsye
You can bridge the stinger on both front and rear. It shows which channels to do that with on the amp. FR+/FL-.. RR+/LR-
