Cicada or Ground Zero
Old Mar 21, 2022 | 08:25 PM
mhill0826's Avatar
mhill0826
Default Cicada or Ground Zero
I am about to order my stuff for install: originally looking at GZ Yellow Baskets, SD 800.4 and an HKI mini DSP. Able to get Cicada CH65.4 and the Cicada DSP150.4D for about $150.00 more. Looking at the best bang for the buck. I’m looking for sound quality or volume, I think either system will be good at Highway speeds. It’s going into a 2019 Street Glide, only going to be running the two speakers, not planning more. I’ve posted a few options here prior, and have gotten good advice. Install is in a few weeks and I need to settle on a system.
Old Mar 22, 2022 | 08:32 AM
Fireball Jack's Avatar
Fireball Jack
If you go the Cicada route and I probably would myself. Look at the CH65.2 that will give you 150W per speaker instead of 90w if you ever want to add 2 more speakers.
Old Mar 22, 2022 | 09:14 AM
mhill0826's Avatar
mhill0826
Looking at the amp specs, it can’t be bridged at 2 ohms, so I would just run it off two channels?
Old Mar 22, 2022 | 10:04 AM
Fireball Jack
If you never plan to do more than a 2 speaker set up, then go for the 4ohm.
mhill0826
Audio Systems
Jun 25, 2025 07:52 AM
Jcoon92
Audio Systems
Sep 22, 2021 09:56 AM
jt metal
Audio Systems
31
Mar 19, 2017 04:47 PM
Vision
Audio Systems
Jun 18, 2016 10:23 AM
Glide2013
Audio Systems
Mar 2, 2014 03:39 PM
