I'm trying to connect my Fosgate PMX-HD9813 stereo to an Stinger spx700x4 amp.
I will be replacing a Hogtunes system do I need any specific wiring harness?
Operating Voltage
9.5 - 16 VDC
Output Power CEA-2006 Power Rating
25W x 4 @ 4Ω RMS
50W x 4 @ 2Ω MAX
≤1.0% THD+N
Output Impedance
< 500 Ohms
Idle Current
< 2 Amps
Frequency Response
RCA: 20Hz - 20 kHz
High-Level: 20Hz - 20 kHz RCA Output Voltage
Front: 4 V Max
Rear: 4 V Max
Sub: 4 V Max
THD+N
4-Ohms: < 1.0 %
Channel Separation
RCA: > 50 dB
High-Level: > 50 dB
Signal-to-Noise Ratio
RCA 2V: > 85 dB
High Level (CEA-2006): > 75 dB
Max Wrms: > 80 dB
AM Tuner
Range: 530 - 1710 kHz
Sensitivity: 40 dB
Frequency Response: 45 to 2.4 kHz
FM Tuner
Range: 87.9 - 107.9 MHz
Sensitivity: 8 dB
Frequency Response: 20 - 15 kHz
Your RF HU should have a small cover that can be removed on the bottom right side of the HU.
You RF HU should have also came with a plug with RCA outputs that gets plugged into the HU.
I see on the harness it has a remote wire, do I need to hook it up and if so were and do I need a loc or a dsp?
its going to be hooked up to a soundigital 800.4 evo4 and the speakers are hertz sx165 neo
tyia!!
If you are talking about the blue remote turn on wire, that goes to the amp to turn on the amp.
No LOC or DSP required. You have a built in EQ in that HU to help with tuning.
