Recently got the bike back from having the top end redone and have a strange audio problem thats cropped up. I am running a Rockford kit on my 15 Roadglide with MMats midbass in the lowers and Arc Audio in the fairing.
The issue that Im having is a crackling type sound in the right channels (both fairing and lower) that only seems to happen when the engine is running. I havent had a chance to take the fairing off and poke around and was hoping someone might have a suggestion on where to look first when I do.
switch the inputs on the amp to right to left. See if the problem follows it. I am aware how RF wires there systems.
i pulled the fairing off this morning and switched the inputs, the crackling sound went away from what I can tell testing in the garage. Must have been a loose connection but they were fully connected when I took them apart.
