GZ 6.5 issues
Old Jul 21, 2022 | 08:35 AM
oly22's Avatar
oly22
Default GZ 6.5 issues
Has anyone else had this issue? Is it fixable or are the speakers shot?
I have a pair of GZCF 6.5SPL speakers in my fairing powered by an SPX700x4, speaker level inputs to the amp from my factory GT6.5. I set the amp bridged, with a meter, to 200W with the high pass at 80 hz as per the dealer. I really like them for the first few months then I started getting distortion, first on the right speaker and now on both. The dealer would not warranty them as there was no physical damage "or instance something coming loose or disconnected, it would be hard to warranty the speaker." This has gotten progressively worse and now they are more than a year old. I upped the high pass to 100 then 125, still have distortion. I hate to toss a $300 pair of speakers after only a year of use. I live in ND so a year of use is really 5 months or so.
Any help or experience, if it exists, would be appreciated. TIA, you all are great.
Old Jul 21, 2022 | 09:17 AM
cshocker's Avatar
cshocker
First I would ohm test the speakers.
Second I would double check the speaker wiring at speakers and at amp. Especially at the amp since it has the plug. Wiggle that plug around and see if that fixes anything.
Is your radio flashed?
Old Jul 21, 2022 | 09:24 AM
oly22's Avatar
oly22
Thanks, I will give each of those a try.
Yes, I have the Rockford flash installed.
Old Jul 21, 2022 | 09:29 AM
cshocker's Avatar
cshocker
I had one set go bad (my own fault) and when you would push on the speaker, it was crunchy. Try that and if is, then time for a new set.
Old Jul 21, 2022 | 11:05 AM
oly22's Avatar
oly22
That is what I am afraid of. Thanks for the help.
Old Jul 21, 2022 | 03:48 PM
golfblues's Avatar
golfblues
Contrary to what a lot of people say about the gz's taking 275+ watts, when they are pushed they disintegrate. Happened to mine too.
Old Jul 21, 2022 | 03:56 PM
memphisharley's Avatar
memphisharley
distortion from the head unit killed my first set. did you find the volume where your head unit distorts.
Old Jul 21, 2022 | 04:06 PM
oly22's Avatar
oly22
No, but I have a feeling that contributed to it. What is the best method to find this volume? I am guessing it is about 3/4 from what I have been experiencing.
Old Jul 21, 2022 | 04:22 PM
memphisharley
not sure on the gts..someone here more knowledgeable will respond.
good luck with her!
Old Jul 21, 2022 | 07:04 PM
Dsm Limited's Avatar
Dsm Limited
On a 18 down 6.5 GT, 3 bars from the top is typically your new max volume, as tested on a DD1.
The GTS is either 3 or 4 from the top, depending on which flash is used.
