Dedicated AMP for Horns, Y/N?
Old Aug 27, 2022 | 09:52 AM
neonflx's Avatar
neonflx
Default Dedicated AMP for Horns, Y/N?
Need some help deciding on whether or not I need a separate AMP for the DA Horns
my current setup is
BT4250 running 2 x SPL 6.5 fearing , 2 x DA Horns and GZ yellow basket 7x10 on lids
SD 800.1 running 2 x MSPRO8
What I want to do since I cant really control the horns and make my ears hurt lol, is to use a Dayton DSP to be able to control the horns,
My question is , do I need a small third amp to run just the horns if using a DSP???
I have an extra DA Micro2v2 laying around that I could use to drive just the horns in addition to adding the DSP, in which case the new setup would look like this
BT4250 running the SPL and GZ
DA Micro2v2 running the DA Horns
SD 800.1 running MSPRO8
Dayton 408 DSP
TIA
Old Aug 27, 2022 | 11:06 PM
cshocker's Avatar
cshocker
my current setup is
Dayton 408 DSP
TIA
You can the horns down some when they aren’t in their own channel with a DSP, but…..you have way more control over them when on their own amp channels. If you can make it work, it’s best to put them on their own amp and DSP channels
Old Aug 28, 2022 | 04:14 PM
neonflx's Avatar
neonflx
I was able to fit everything inside the fearing, so 3 amps and DSP it is, thanks for the feedback
sbeamer
Audio Systems
Jul 26, 2021 11:37 PM
ohcie
Audio Systems
Mar 29, 2020 02:51 PM
groovna
Audio Systems
Aug 3, 2018 07:05 PM
Geary Thomas
Audio Systems
13
Mar 2, 2018 04:29 PM
sponger
Audio Systems
Sep 5, 2017 05:16 AM
