AMP Ground Wire
Old Sep 26, 2022 | 08:45 AM
kloccwork419's Avatar
kloccwork419
Just ground to where the battery is grounded to the frame. NVS has a great video on it. Get 12” 0awg cable and upgrade the battery ground while your there. That way you have 1 cable to your battery and the accessories are grounded to the bolt on the frame. Its not hard and its right there by the battery
Old Sep 26, 2022 | 09:19 AM
Hoyt 1911A1's Avatar
Hoyt 1911A1
I thought about doing that but I think I decided to leave that space clear for possibly getting that blower fan that mounts behind the rear cylinder that Harley makes. It gets so hot around here in the summer if my Wife is not going with me I don't even ride the Geezer Glide, I just take one of the nekkid bikes. I had heard some good reviews about that fan when stopped in traffic. I don't get involved in traffic much so I don't know if I'll ever get around to trying it out, just a thought.
Old Sep 26, 2022 | 10:53 AM
yooperhog's Avatar
yooperhog
Am I the only guy using distribution blocks?
Old Sep 26, 2022 | 01:23 PM
Hoyt 1911A1
I was actually going to try that route but I have so much junk added to my system that most folks don't that I didn't really have room for them. I wound up just getting some zero gauge terminals and putting all my eight gauge wires into them and crimping them down. Not pretty but compact and reliable.
Old Sep 26, 2022 | 03:04 PM
kloccwork419
no
Old Sep 27, 2022 | 05:49 PM
Dsm Limited's Avatar
Dsm Limited
Aw heck no!! I’ve got a few of em!!!😁😁
and the the 2 for ground are back to the battery!
Old Sep 27, 2022 | 07:39 PM
Inop's Avatar
Inop
I used one of the two ground studs on the left side between the tank and the battery
Old Sep 27, 2022 | 08:06 PM
downzero's Avatar
downzero
Originally Posted by Hoyt 1911A1
Another issue that comes up is if several high current amps are grounded to the frame the factory battery strap could not handle the load and should be upgraded. As long as folks remember that I imagine everything would be fine, but if someone forgot to install a heavier gauge run from the battery to the frame I would think that it could easily be overloaded.
I'm sure the factory battery cable is capable of moving more current than the charging system can ever generate to replenish it.
Old Sep 28, 2022 | 04:42 AM
kloccwork419
Its like doing the big 3 in a car. Upgrade the cable. Its not meant for after market amps and all the accessories. Its 12” of cable. 2 bolts.
Old Sep 29, 2022 | 05:21 AM
Dsm Limited
Nothing on a stock bike draws more than 50 amps. The stock cables are designed to hold those loads. Aftermarket amps (especially multiple amps) can easily exceed those loads. Depending on the setup, I wouldn’t want 100 amp draw going through a cable spec’d for 50amps.
