There are four precision power 1000.4 amplifiers,
one in each saddle bag running a PRV ten and a PRV 6x9, and yes they are separated, both bridged to put 500 watts to each speaker, gains are turned down on the 6x9s to keep them at about 300 Watts, 28 volts I believe,
Then there is one 1000.4 running PRV 6.5s in the lowers bridged 500 w each
The last one is run in stereo, picking up 6.5 UN crescendos these are getting 140 w each
and four PRV tweeters on the rear channel s
The DSP is a Dayton audio that is what the question is in reference to the master gain on the DSP as well as each individual gain on the DSP are you guys setting those at zero when setting your amp gains?
