I’ve noticed that the power rating on some of these amps is rated at 2 ohms so when you connect a 4 ohm speaker you get less wattage. I am looking to get 150-200 watts per channel @ 4 ohms.
and am thinking of yellow baskets which like power.
the sd evox 400.2 is 132w x 2 @ 4 ohms
stinger 350.2 is 125w x 2 @ 4 ohms
so i figured if i can find a 600 ish watt amp it should get me into the range i want.
Ive noticed that the power rating on some of these amps is rated at 2 ohms so when you connect a 4 ohm speaker you get less wattage. I am looking to get 150-200 watts per channel @ 4 ohms.
Look at the SD400.4 EVOX and bridge the channels. That will give you 200W per channel.
