2010 streetglide mode button
Old May 18, 2023 | 11:24 AM
mericleman50's Avatar
mericleman50
1st Gear
Default 2010 streetglide mode button
So the radio mode button will work in accessory but not in the ON position of ignition. I’ve ohmed the wires, and did a diagnostic test on the radio and got a B2007 code I’ve got the bars off for the third time when you press the button you have continuity through the brown/white and violet/black. Non of the wires go to ground or have continuity with other wires. Can anyone help?
Old May 18, 2023 | 11:27 AM
mericleman50
1st Gear
The button does work when ignition is in accessory position but not when in the on position.
Old May 18, 2023 | 01:05 PM
NorthWestern's Avatar
NorthWestern
B2007 Handlebar switch shorted high handlebar switch Radio Short mass
Ignition ON Ignition OFF for at least after 10 sec., T = instantaneous
Old May 19, 2023 | 03:18 PM
mericleman50
1st Gear
Can you explain it better that kinda of confusing?
Old May 20, 2023 | 03:52 PM
NorthWestern
I looked up the code for you, that was the description I found with the code that you gave. If you Google that code, that info comes up.
Clearly there is a short. You are not going to just clear it. Time to start eliminating and finding the short, it is likely in the bars or the switchpack, based on that code description
Old May 21, 2023 | 08:08 AM
mericleman50
1st Gear
I went through and ohmed every wire, none went to ground, just stumped why it works on accessory but not ignition on.
Old May 22, 2023 | 07:56 PM
mericleman50
1st Gear
Default Pre wired bars
Prewired bars had left handlebar connection had a violet/black wire harness. When I didn’t have that connected the mode button worked fine. Removed that wire from connector and all buttons work fine now.
Dawort
Audio Systems
Jun 25, 2015 08:20 PM
magilla_gorilla
Electrical/Lighting/Alarm
Mar 6, 2015 12:39 PM
cbears
Apr 9, 2014 10:14 AM
Pavo
Jun 7, 2012 07:28 PM
Trippie
Nov 12, 2009 09:27 PM
