Stereo upgrade
Old May 6, 2024 | 05:54 PM
Jordan93's Avatar
Jordan93
Will I need a special bracket to mount this on top of the deck?
fastsoup's Avatar
fastsoup
No, some zap straps and velcro go a long way.
If you want a "clean look" then yes spend the money.
Old May 6, 2024 | 05:55 PM
Weeboy1's Avatar
Weeboy1
Originally Posted by fastsoup
OK, my bad...here is what I would do to keep costs low. You say it's loud enough for you but not clear...so spend a little money and get yourself a stinger spx 700, wire it up to each of those Hogtunes speakers and set your gains using an oscilloscope (cheap to buy on Amazon) and cross the HP freq around 100hz. If after that you are happy, then good, if not, I'd start by replacing the fairing speakers to something more efficient.
I agree , and you can likely get that amp for under $500 cad.
FS nothing on your shelf to offer up? And you’re in the neighborhood…..lol
Old May 6, 2024 | 05:56 PM
fastsoup's Avatar
fastsoup
lol...I got a 1200.4 EVO that needs repair (can't find anyone local) and a set of Polk MM652's. Possibly a set of GZ Yellow baskets and Hertz Neo 6.5 in the coming months.
Old May 6, 2024 | 05:57 PM
Jordan93's Avatar
Jordan93
Ya I can get that amp here for 380 cad
Old May 6, 2024 | 06:43 PM
Jordan93's Avatar
Jordan93
Will I need a special wiring harness, been a long time since I replaced the deck I can’t remember if I’ll just need to splice into the speaker wires or get a different harness for my 09
Old May 6, 2024 | 08:23 PM
fastsoup's Avatar
fastsoup
No splicing...deck will have RCA preouts...get 6ft of 8gauge ground/power wire and remove the tank to make running the wire easy. 2 set of 1ft RCA cables...and remote turn on wire off the HU - buy a cheap oscilloscope off Amazon to set gains properly without distortion.
Old May 6, 2024 | 08:45 PM
Jordan93's Avatar
Jordan93
Thank you !
Old May 6, 2024 | 09:27 PM
Jordan93's Avatar
Jordan93
This might be a dumb question but I see there’s no jack for rca input on that stinger amp does it come with a plug that goes into the amp to a female rca jack? Or how do you wire from the pre outs on the aquatic deck
Old May 6, 2024 | 09:33 PM
fastsoup's Avatar
fastsoup
It comes with an adapter - allows either RCA or Hi-level input.
Now start doing your own research 😜.
