Apple car play audio issues
Old Nov 20, 2024 | 09:34 PM
Hunter2010's Avatar
Hunter2010
6th Gear
Default Apple car play audio issues
Having audio issues using boom box gts after updating I phone to iOS 18 .
So when music is playing and making a phone call or text message the audio stops which is correct but when the call is finished the audio returns with horrible quality sound . It’s all muffled and no stereo . My boom box gts software is updated and my whim is updated as well . I tried multiple phones with same outcome. Tried multiple Apple brand cables same issue.
Then I tried an older phone 6 with iOS version 12 and it worked no issues, music returned perfect . Has to be the Apple update .
Has anyone experienced this? Or have any suggestions?
Thank you
Ira
Old Nov 21, 2024 | 11:38 AM
702's Avatar
702
I just checked to see if mine does what is happening to you.
iPhone 15 Pro
IOS 18.1.1
I use a wireless CarPlay adapter, but that shouldn't matter.
Mine works fine, no issues.
Old Nov 21, 2024 | 03:51 PM
Hunter2010's Avatar
Hunter2010
6th Gear
Thanks for responding , the boom box gts must have an issue . Is there a way to reset it ?
Old Nov 21, 2024 | 08:08 PM
702's Avatar
702
Have you restarted your phone?
If you're streaming music, sign out then sign back in.
Old Nov 21, 2024 | 10:32 PM
HFS's Avatar
HFS
Mine did the same, I just hit the button to have Siri come on, cancel and let her go away, and it fixed itself.
Its not a 'fix' but a workaround for the short term. Really unimpressed with the GTS / WHIM / SENA debacle.
Old Nov 22, 2024 | 08:13 AM
Hunter2010's Avatar
Hunter2010
6th Gear
yes, restarted phone and did hard reset. Tried multiple family phones with the latest update all had the same issue, Thanks for responding
Old Nov 22, 2024 | 08:39 AM
Hunter2010's Avatar
Hunter2010
6th Gear
The Siri command didn't work, but hitting the voice button quick brought up the boombox submenu of popular commands which after it cancelled the music returned to normal. Thank you so much for this work around , I can live with this... The boombox GTS system has many flaws especially the partnership with Apple and getting Carplay to work correctly. It's ridiculous you are forced to use a Harley branded headset or you lose most of the Carplay functionality. All the major helmet companies are making high tech built in wireless headsets and we can't even take advantage of that. Harley once again keeps us in the stone age because of being greedy . You used the prefect word debacle!!
Please let me know if you ever figure out the issue, hopefully an update for something will resolve this down the road.
Old Dec 16, 2024 | 06:47 PM
etrass's Avatar
etrass
Stage I
Default Having the same IOS 18 issue as Ira.
Ira, did you ever get the iOS / CarPlay issue solved?
Old Dec 19, 2024 | 12:17 PM
mikes300's Avatar
mikes300
I would imagine this is just a glitch on apples part with the update, they will fix it I'm sure, hopefully sooner than later
streetglide2019
Aug 26, 2021 06:06 AM
Jskinner6483
2014-2024 Touring Models
Jan 5, 2017 03:59 PM
Chief45
Audio Systems
Jul 10, 2016 04:37 PM
N3WWL
Apr 20, 2016 12:26 PM
TimLScheffer
25
Sep 3, 2014 08:21 PM
