Techno Tool Won't Connect
Old Jan 7, 2026 | 10:54 AM
truejdm's Avatar
truejdm
Default Techno Tool Won't Connect
Added a Cicada amp with front speakers, and lids. The techno tool is saying I have an aftermarket ECM and will not connect to flash. Currently sitting with the 00_OFF.bin file on my 2016 SGS
Any thoughts?
Old Jan 7, 2026 | 11:36 AM
cshocker's Avatar
cshocker
Any thoughts?
Call Techno, leave message for them to call you back. They can help you and remote in and see what's going on.
Old Jan 9, 2026 | 08:15 PM
Bass-M's Avatar
Bass-M
Pull the ECM. Bench flash it with a programmer. The off file corrupted it. That's your only fix.
Old Jan 9, 2026 | 11:01 PM
NorthWestern's Avatar
NorthWestern
No, Mr. AI Bot, that is not correct.
Old Jan 10, 2026 | 03:07 PM
marcodarq's Avatar
marcodarq
ok, first off, do you have an aftermarket ecm, like Thunder Max, or Daytona Twin tech?
if so,,,,you need to install the HD ecu then flash it.
Second,,,is your techno tool up to date for the year of bike you are working on?
The cutoner service that i've always gotten has been top notch,,,,give them a call.
m
Old Jan 12, 2026 | 03:27 PM
truejdm's Avatar
truejdm
I dropped the bike off at an Audio shop here in town after I did the install. The ECM looks to be factory. OEM part number # matches to factory. I bought the bike used, so unsure if it has been tapped into. I'll ask about being up to date. I did call my local Harley dealer, and they said they can do it no problem. They've done it for the setup I have actually.
wadejesu
Nov 1, 2025 07:25 PM
Deznan
May 31, 2025 09:35 AM
obd2works
General Topics/Tech Tips
May 31, 2014 04:00 AM
peddler
Feb 6, 2014 08:45 AM
