Amp keeps cutting off
Old Apr 3, 2026 | 10:58 AM
JayLo's Avatar
JayLo
Default Amp keeps cutting off
Having an issue with my audio on my 19 RG and want to see if y'all can help me out.
I have Ground Zero's yellow baskets up front, Memphis MXA62HD on the tour pack pods with a Sound Digital 800.4 EVOX-4ohm pushing them with stock GTS radio. Ive had the system installed since 2021 and its been fine until last fall (didn't do much riding in the winter).
Last fall while going down the road, it seems like the amp just cut off and music was playing, but flat. Pulled over, turned bike off and then back on.....and it came back to life.. Took it to place of install and they said everything was working fine and couldn't find anything wrong with it. I thought it was a one time thing until yesterday. Went for a ride and about 15-20 minutes in, amp cuts back off again. I just kept riding and it came back on about 30 minutes later on its own.
Any ideas?
Thanks in advance
Jay
Old Apr 3, 2026 | 12:58 PM
cshocker's Avatar
cshocker
My guess would be the amp is going out. Those SD amps don't have a great reliability track record. If the shop did a just job on checking everything out, then it would be the amp. Double check battery terminal screws are tight under seat..
It would be best if you could pop the fairing off when the amp stops to see if the amp is powered on or not.
Old Apr 3, 2026 | 08:01 PM
Babyboy's Avatar
Babyboy
Any ideas?
Thanks in advance
Jay
What volume level is the headunit at when the audio shuts down??
Are you using Bluetooth or hooked up thru the USB for your music?
Old Apr 3, 2026 | 08:35 PM
JayLo's Avatar
JayLo
I was thinkin it might be the amp too but wasn’t sure. Everything is tight going to the battery.
Volume level is about half or maybe 1 bar over halfway. It definitely wasn’t cranked up as I was riding back country roads going 40-50mph. The phone was hooked up to the USB going into the bike and using CarPlay. Just playing music from my playlist.
Jay
Old Apr 4, 2026 | 08:43 AM
cshocker's Avatar
cshocker
Jay
Ride again and if it goes out, switch the FM and see if you get any sound. That will at least let you know its not the phone or CarPlay.
MeteorWitch
Audio Systems
Feb 12, 2025 06:44 PM
UHDhog
Audio Systems
Oct 4, 2024 07:36 PM
ScoobyDooHarley
Audio Systems
Aug 4, 2018 04:21 PM
Bertk
Audio Systems
Jul 8, 2016 06:21 PM
bgismo20
Apr 16, 2008 03:05 PM
