Bluetooth Earbuds Won't Sync
Old Apr 4, 2026 | 11:30 AM
fredman730's Avatar
fredman730
3rd Gear
Default Bluetooth Earbuds Won't Sync
2023 FLHX with standard Boom! Box GTS. None my earbuds are recognized by my SG's audio system. In Bluetooth setup it scans for devices but never finds any of the earbuds even if I manually set them into pair mode.
All I wanted was to route audio to bluetooth earbuds for better audio at lower volumes while on the highway. Less wind noise would be a plus.
I've found I can route my music on my phone through the bikes audio and can control tracks but not volume.
Wondering if an android car play would give me track AND volume control through handlebar controls?
Really don't want to put a phone holder on the handlebars to make the phones controls available.
Thoughts? Thanks!
Old Apr 4, 2026 | 02:20 PM
chopper_man's Avatar
chopper_man
Bike off, in accessory mode, set radio to BT pairing, open AirPod case, press little button on back of case and they should show right up on the radio. That's how mine paired.
Old Apr 4, 2026 | 04:10 PM
fredman730's Avatar
fredman730
3rd Gear
Unfortunately that's not working for me. Bike's in Accessory mode, set earbuds to pair mode, start pair scan on the bike and it scans for 30 seconds or so. No recognition or connection.
Same result if I remove earbud pairing from phone first.
Tried removing and adding phone back on the bike. No problem, pairs right up.
I was able to add earbuds back to phone without issue.
BTW, I've tried the process with three different sets of earbuds from two different manufacturers.
Worst case, I've gotta get the bike serviced before I head out on a 2K mile so I'll ask them about it then.
You'd think bluetooth would behave better by now.
Old Apr 4, 2026 | 06:15 PM
cycle7447's Avatar
cycle7447
Community Influencer
I didn't think you could pair any Bluetooth heads to the Boom Box GTS without the use of a WHIM.
If I am correct, and all you want to do is pair your buds, I might suggest installing a J&M dongle. Installing this will also give you handlebar control for your volume and other functions.
You cannot
Can you pair Bluetooth headsets to the Harley Boom Box?
Currently, you cannot directly pair any brand of wireless Bluetooth headset with the Harley Boom Box. The Boom Box is designed to work with a wired headset and does not support the Handset Profile (HSP) for Bluetooth headsets. Instead, Harley-Davidson has introduced the Wireless Headset Interface Module (WHIM), which allows for the pairing of wireless Bluetooth headsets with the Boom Box. This module must be installed by a Harley-Davidson dealer and is required for models that do not have a WHIM pre-installed. The WHIM is available for purchase separately and is necessary for models from 2014 and later
CageyKG
Audio Systems
16
Aug 6, 2023 10:19 PM
cskarns
Audio Systems
Mar 14, 2015 09:49 PM
Yamsx210
Apr 9, 2013 09:49 PM
troop
Aug 5, 2010 09:39 AM
mikes99EG
Oct 31, 2005 07:50 PM
