Playing Boom 6.5 through Cardo PackTalk
Old Feb 26, 2022 | 07:42 AM
CageyKG's Avatar
CageyKG
Default Playing Boom 6.5 through Cardo PackTalk
I can't seem to find the answer to this anywhere. I am considering getting the Cardo PackTalk to communicate with friends on rides, but before I do I want to know if it is possible to play music through the Cardo speakers and be able to control everything (volume, track, etc) through the controls on the Boom 6.5. If so - how do you do it?
I understand that I can pair my phone with the Cardo and play music that way, but I really want to be able to use the controls on the handlebar and be able to see the track on the screen. If it can't be done, it can't be done, but I have to imagine it's possible somehow.
Thanks!
Old Feb 26, 2022 | 08:45 AM
Cajun4x4's Avatar
Cajun4x4
Maybe this will help. Ran into a similar problem with prompts not coming through my headset. Go to audio settings, Audio Routing; then on the next screen use the right hand toggle to move left or right to select speakers or headset for each section.
Old Feb 26, 2022 | 10:37 AM
CageyKG's Avatar
CageyKG
Do you have the WHIM installed on yours? Just curious if it would work with the Cardo without it.
Old Feb 26, 2022 | 01:25 PM
Cajun4x4's Avatar
Cajun4x4
Yeah it came with the WHIM. That's only way a wireless headset can connect to these radios.
Old Feb 26, 2022 | 03:22 PM
lefty33's Avatar
lefty33
Thanks!
I have a pair of Cardo PackTalk's that my wife I use. We have a 2020 RGL with the GTS head unit, no WHIM. Pretty sure you can do what you're asking. This is how I do it and it works perfect for me.
My Cardo is connected (bluetooth) to my iPhone, then the iPhone is connected (bluetooth) to the GTS head unit. I listen to my music streamed from my iPhone (Spotify).
Because the phone is connected to the GTS, I use the thumb controls for controlling the music. With AirPlay from the iPhone, I can choose to send the music either to the Cardo speakers or the bike speakers.
I can receive phone calls this way if I want (I generally don't as it's my get-away time), and the number calling & info shows up on the GTS screen.
The battery life in the Cardo is awesome! Gone on multi-day trips, listening to music & communicating with others all day and not run out of battery power.
The extended battery power, JBL speakers, fully waterproof (most aren't), range, mesh technology, and fantastic communication are reasons I went with the Cardo PackTalk.
About the only thing I can't do is use my CB wireless but that's not that big a deal as I'm using it less all the time. Jury is out if would work if I got the WHIM...but then I'd loose stereo sound.
Old Feb 26, 2022 | 07:34 PM
CageyKG's Avatar
CageyKG
Thanks! I was able to confirm what you said and even found a video of a guy doing exactly that. I'm so relieved!
Old Feb 27, 2022 | 10:05 AM
lefty33's Avatar
lefty33
Yup...I think I saw that video some time ago. Couple of other things I thought of...
- if I remember correctly, when listening through the Cardo speakers, volume still needs to be adjusted on the Cardo. That's no big deal as it auto mutes the music as soon as communication starts on the Cardo
- I don't think you will get Nav prompts through the Cardo speakers. Again, no big issue for me as I don't care for the audio nav prompts and have that feature turned off anyway.
Good luck! The Cardo is a great unit and does everything I need it to.
Old Mar 21, 2022 | 09:45 AM
TexasMotorcycleRider's Avatar
I have a Cardo Packtalk and XM on my Boom and it works using a Sena Freewire. I had to connect the Freewire using the 7-pin DIN kit from Harley and connected to my Packtalk, it works in stereo. Connecting with just the WHIM does not give you stereo unless you have a HD branded headset. I have a thread somewhere in here regarding the details of using the Freewire, that was when I was using the Bilt helmet with the built-in BT headset. If you have a WHIM already it should connect using your Bluetooth settings on the radio.
Old Mar 21, 2022 | 12:25 PM
lefty33's Avatar
lefty33
Good info as I have a Cardo PackTalk as well...no WHIM. Not sure if you can answer this or not, but do you know if you can access the CB wireless with the Cardo/Freewire combo? I believe you can with the HD branded Sena/Whim combo.
Old Mar 21, 2022 | 01:27 PM
Despite being BT 4.0 and in stereo, the PacTalk will not work for audio input. Sena has this restriction on their Freewire and Harley has a restriction on the WHIM. You need a Sena headset that is at least BT 4.0 and then the voice commands and CB should work.
These OEM's make it difficult to use other brands. Harley and the WHIM, you can connect a non-harley but you can't use voice commands and your output is MONO. Freewire works on any headset and in stereo but you have to have the Sena to use the microphone.
