Hi ultraglide12, looks like the Aquatic can be had on Amazon for $588 CDN
at this point Ill likely just go with the two fairing speakers would $1000 for amp and speakers be realistic?
If you have deck already I don't see why you couldn't get amp and a couple speakers for a grand. For two speakers budget friendly alot of guys say the stinger 700 watt amp and a set of mmatts 6.5 speakers are fairly good setup unless things have changed lately . with our dollars it sucks buying from usa . I'm sure someone with more info will pop in. Good luck
I just seen the new soundstream deck just came out it looks interesting and has car play and android auto that is 2 ohm friendly .
For what its worth i still run the factory head unit because it has the ipod controller with it I just added a amp and speakers
