What can I expect from an stereo amp?
Old Apr 26, 2011 | 08:24 AM
pauletich's Avatar
pauletich
Default What can I expect from an stereo amp?
I have a 07 FLHX, with the stock HK stereo, I have upgraded my speakers to the J&M 7.25 and have the hog pod dash speakers. I would like to know if I get an amp installed what I can expect? If I have the volume set to 6 squares now and install a amp would the volume set at the same level make the volume set at 6 square sound like it is set at 7, 8, 9 or high squares? Sorry I am not a stereo guy and not sure if this makes sense.
Old Apr 26, 2011 | 03:15 PM
UltraNutZ's Avatar
UltraNutZ
you will effectively achieve the same sound level at a lower "volume level on the radio" than without an amp. Lower volume on the radio means lower distortion therefore producing better sound. So to answer your question; Yes, most certainly with the speaker setup you have would I add an amplifier.
Twotone2t
Jun 24, 2019 05:19 PM
NVERL8
Audio Systems
13
Feb 16, 2017 07:31 PM
Airhead59
Audio Systems
May 20, 2013 01:56 PM
09B29
Audio Systems
Nov 2, 2012 07:17 PM
pauletich
Apr 26, 2011 12:03 PM
