FLH antenna help
Old May 25, 2011 | 07:10 PM
trigger1911's Avatar
trigger1911
Default FLH antenna help
I dont want an antenna sticking up on my ultra classic. I have seen antennas that are just 2 wires on a roll of clear plastic tape that you cut to length. Any idea what it is called or where i can find it? I looked in the limousine application to no avail. Thanks
Old May 26, 2011 | 12:33 PM
UltraNutZ's Avatar
UltraNutZ
pick up an amplified antenna and install it inside the fairing is your best bet.
To do it your way, pick up an antenna plug at radio shack, get you a 28.5" piece of speaker wire (both leads). solder it together to the plug and stretch the wire inside your fairing. 28.5" will be more than sufficient for the 88-108MHZ range of stations.
tankplunkett
Apr 17, 2013 04:35 PM
traveler
Apr 5, 2011 08:18 AM
THABULL
Mar 18, 2008 09:04 AM
kayman
Mar 14, 2008 09:15 PM
Mathews2
Jun 19, 2007 07:21 PM
