Splitting front channels before amp?
Old Feb 17, 2013 | 01:33 PM
Dew Me's Avatar
Dew Me
Default Splitting front channels before amp?
I'm thinking about splitting each front out (wires not RCA) off the RK so one wire goes directly to tweets and the other goes to the amp (for each channel). What happens if I do this? Will the tweeter get the preamp power? If so how much power is that? Does this degrade the signal going to the amp?
Old Feb 17, 2013 | 07:08 PM
UltraNutZ's Avatar
UltraNutZ
The stock head unit is roughly 20w RMS (give or take as I've never seen true specs on it) and wiring it this way will in no way affect the quality of the signal to either the tweeters or the amp.
Old Feb 17, 2013 | 07:42 PM
Dew Me's Avatar
Dew Me
20w RMS to the front? Is that @ 2 ohms or 4ohms?
Old Feb 17, 2013 | 08:42 PM
Pioneer74's Avatar
Pioneer74
2 ohms.
Old Feb 17, 2013 | 09:44 PM
Dew Me's Avatar
Dew Me
Originally Posted by Pioneer74
2 ohms.
I think all the separate tweeters I've seen are 4 ohm. If the pre-amp is 20 watt @ 2 ohm, doesn't that mean that it is 10 watt @ 4 ohm? I think Focals Tweeters are the only ones designed to work at 10 watts and 4 ohms.
Old Feb 18, 2013 | 07:47 AM
UltraNutZ's Avatar
UltraNutZ
man you sure like complicating things dontcha! :-)
No, increasing the impedance from 2 ohm to 4 ohm on a 20 watt amp doesn't mean it drops the output power by 1/2 but it will drop it significantly. 1/2 is a rough "estimate". Every amp is different so there are 2 ways to tell what you will see in a 4 ohm load vs a 2 ohm load.
1.) you measure it (the outputs of the amp) with an oscillosope
2.) manufacturer's specs usually tell you this information on a 2 ohm stable amp.
What I've said time and time again on this forum is that you do NOT need to pay (too much) attention to impedance with tweeters because of the frequencies they produce. The way a tweeter works (at the high frequencies it's designed to work at) essentially mitigates any effect it's going to have on total impedance an amp sees.
Old Feb 18, 2013 | 08:03 PM
Dew Me's Avatar
Dew Me
I really am sorry but I want to do it right and get the max outta my project. Considering the environment and characteristics of highs, they have the most danger of never getting to my ears. You have stated you are not big on highs and I want to make sure I'm getting enough.
Here's where I'm at:
1. I know I am not touching the rears. I'm hoping to wean myself off the TP soon so rear speakers won't even be on the bike. If that changes and I decide I want better rear sound, I'll probably mount an amp under the TP for rears.
2. I know I'm doing the SS 4.520D and know I will bridge it.
3. I know I'm putting MM651's in batwing
4. The lowers will either be MM651's or MM6501's:
a.)MM651's in lowers and Focal tweets in gauge holes, receiving 10-15 (?) watts RMS.
b.)MM6501's mounted so woofer goes in lowers and tweeter is mounted up in gauge holes.
Will any of the highs get to me if I put MM651's in the lowers?
Old Feb 19, 2013 | 07:33 AM
UltraNutZ's Avatar
UltraNutZ
no need to be sorry.. just giving ya chit man... First off I never said I wasn't big on highs. What I said was I don't think they're necessary with these MM651 speakers and to try the setup without the additional tweets first before you go drilling holes or removing gauges. To me, too much highs can be so over-bearing in certain setups and just absolutely ruins the whole audio experience.
so are you planning on wiring the fairing and lower speakers in series?
Old Feb 19, 2013 | 12:54 PM
Dew Me's Avatar
Dew Me
Yes. If the equation I found is correct. bridging the SS, and wring in Series, will produce 96.2 RMS per speaker. Damn near perfect.
Old Feb 20, 2013 | 11:30 AM
Dew Me's Avatar
Dew Me
If I am determined to replace two gauges with tweeters is it better to use HK pre-amped Focals? Or is better to use the amplified component tweets from MM6501's?
I'm doubting wind is going to allow much highs to get to me from lowers when using MM651's at speed. If highs are useless from MM651's in lowers at speed I might as well do the MM6501's down there. If highs will get to me from MM651's in lowers (at speed) then I will install pre-amped Focals in gauge holes.
DoubleD8
Audio Systems
Apr 14, 2019 04:32 PM
bettingpython
Audio Systems
Jul 14, 2015 06:15 AM
Payner
Audio Systems
Feb 15, 2015 05:58 PM
ckef_koran
Audio Systems
Apr 21, 2013 06:27 PM
dontdropit
May 17, 2009 11:00 AM
