Adding headphone jack???
Old Feb 20, 2013 | 09:38 AM
0ldhippie's Avatar
0ldhippie
Default Adding headphone jack???
How do I add a headphone jack to my system? I have a Kenwood head unit and Jl 400/4 amp (using RCAs) running two fairing and Lowers speakers. I'm thinking of using the unused speaker outputs from the head unit but will I need a pot or resister to lower the output? What size? Also is it OK to hook the speaker grounds together at the headphone jack? Been along time since I messed with Ohms law...
Old Feb 20, 2013 | 02:41 PM
UltraNutZ's Avatar
UltraNutZ
man there's a couple of different ways you could go with this.. I don't know about the Kenwood head units and I'm sure it's going to be model specific based on whether they're high wattage or not as to whether the internal grounds are isolated. If they are isolated, no you you won't be able to tie them together. My suggestion is;
get a PAC or similar adapter for speaker wire to RCAs then convert that from RCA to 3.5mm plug.
stevepacman
May 30, 2013 08:11 PM
flyboy1220
Dec 5, 2011 09:59 PM
agapsdiver
Mar 25, 2008 09:20 AM
kwgrimes
Mar 2, 2007 01:31 AM
roop
Sep 30, 2006 11:42 AM
