Thanks for the picture booch but I'm mounting my equipment in the factory Batwing Fairing, so I don't have as much room as you do.
I'm probably going to attach the cross-overs to the horizontal metal braces that attach to the bottom mounting screw of each speaker (if there is enough room to reinstall the fairing). These are "angle" brackets, so I'll use 3M body side molding tape to adhere them to both the vertical & horizontal surfaces of the bracket, then add the extra security of some zip-ties. This tape is amazing, in that it will not come loose, unless you pry it loose.
I've abandon the idea of mounting the cross-overs for the rear speakers in the fairing (I'd have to run additional wiring) or putting them inside the factory rear speaker pods (they interfere with speaker installation). I plan to mount them inside the TourPak.
Thanks guys! I mounted them to the braces with body side molding tape and zip ties. The body side molding tape wasn't necessary but it should create a little bit of a "cushion" so that nothing rattles.
