Well I have the 6.5's in the lowers and the 7.1's in the fairing. With the BT2180 amp and a 2ohm load I have around 500watts of sound in my face. It is very loud and clear also.
Anyone switched to these from Fosgate T1652s? I did the pre-order on the HAT drop in 5x7s, but have yet to hear any of the HAT speakers. I do have a PBR 300x4 (my 3rd).
Sorry, but I'm trying to understand what you're saying here?
The efficiency numbers on those speakers all spec out to below 90db @ 1 watt.......... Weird that the 6X9 has the highest effiency rating..... too bad the frequency isn't lower........
IIRC,.........Nutz has stated MANY times that he wouldn't buy a speker that spec'd out below 90.
As a barometer,....I think the Polk MM's are at/close to 94.........
Doesn't mean they can't sound good,......just means it takes some pushin' to get them there.
The spec chart has all models above 92 the way I read it.
