PBR300X2 question
Old Apr 4, 2013 | 11:06 AM
fxlowboy's Avatar
fxlowboy
Default PBR300X2 question
just finish the installation of my PBR300X2 and MM651 front speaker wrap with poly and did the setup procedure everything is ok the sound is great :-) i closed everything and did the final test,when i crank up the volume for a moment i smell something like burning and after the smell dissipate.Is it normal ! I double check everything the ampli is not hot ,10 gauge wiring and a good ground, don,t see anything wrong.
Old Apr 4, 2013 | 12:31 PM
Mentalmadness's Avatar
Mentalmadness
Maybe the newness inside the amp needs to break in?....Hopefully someone else can offer insight
Old Apr 4, 2013 | 01:02 PM
sl33py's Avatar
sl33py
I know new PC's will have some smells associated as they "burn in".
I would pull the batwing and just crank it for a while and see if you can locate the smell. Cycle it on and off, w/ some cooling time in between, and make sure it's 100% before you button it back up.
Would like to see how you wrap the speakers with Poly if you don't mind getting a pic? Depending on the actual smell - hot vs burning. I'd make sure some of hte poly isn't in the speaker melting?
HTH - GL!
Old Apr 6, 2013 | 01:59 PM
fxlowboy's Avatar
fxlowboy
took my fairing off drop a cd and crank up the volume for 15 minutes ,no more smell the amp get warm but not much, i think the smell came from the amp when i put power for the first time.
The sound is amazing i love it
now just need the weather to warm up and hit the road .
Biggzed
Audio Systems
24
Apr 3, 2018 03:27 PM
murph
Apr 11, 2015 11:15 AM
scooper321
Audio Systems
Mar 27, 2015 09:46 PM
kishstl
Audio Systems
May 24, 2014 06:54 PM
FXDFan
Audio Systems
11
Mar 15, 2014 07:51 PM
