What's WRONG with JM Audio
HD tech services can provide part numbers for every component in that expensive harness and make a repair easy w/o replacing the entire harness.
By the way, I'm not surprised that your dealer or HD suggested an $1100 repair instead of a $100 fix. Cruise control, audio, and audio harnesses fail and HD won't replace the entire harness when a simple cionnector or wire repair will suffice.
As I've posted here previously, and a relatively long time participant/contributor, I have never read of a similar problem; I have read of folks using HD headsets having problems with the connector; which is why I'm sympathetic to J&M' s position.
Carl
A year old bike with 4000 miles on it and because of age and mileage they won't repair but replace the part. I call TOTAL BS on this line of thinking and borderline extortion tactics from your dealership sir.
No offense here MW but I really think you need to find another dealership to take your bike to for warranty repairs and maintenance. Essentially what this dealership is doing IMO is telling YOU exactly what YOU want to hear regardless of whether it's the right thing to do or not. This in my eyes makes for a bad experience waiting to happen with a dealership that will lie to YOU about YOUR bike for 1 reason and 1 reason only, MAKE MONEY. If they'll do this over something as silly and simple as a headset plug that is easily replaced and as HPM pointed out can be done by any competent tech with a manual, then they will screw you the first chance they get.
So that leads me to the next question. What exactly does "willing to work with you" mean in reference to the dealership if J&M doesn't come across? Does that mean instead of $1100 they'll only charge you $1025? I'm telling you man.. RUN from this dealership. They see an opportunity to screw someone and they're going to do it whether it be you or someone else.
The Din plug that's used here is called a Euro-Din plug and can be bought at radio shack for less than $8. Or if you want one that already has wires on it to make for easy splicing, look to graingers, digikey, or someone like that.
I can tell you that me personally; I've dealt with John himself in the past as well as his employees and I've bought product from him for about 10 years as well. And it's been nothing short of stellar in all aspects. Sturgis this past year I saw John's booth at BH HD so I brought a buddy of mine who I knew was listening to RAP tunes on 5-1/4" J&M speakers in the fairing and toasted them, right up to John's booth. When John listened to it, determined the speakers were blown, pulled this guy's fairing apart, replaced both speakers, put his fairing back together, wiped down the front of his bike for fingerprints all done by JOHN himself that tells me 1 thing; customer service is important to him. John had NO CLUE where those speakers came from and all he was concerned with was they touted the J&M name so he took care of business. I can also tell you this much.. when you have a problem with something you purchased and call or email the manufacturer of said product you will MOST likely not get THE MAN on the phone or responding to your emails.
So in the end, again I advise you to find yourself another dealer and stop peddling this crap here. I think everyone (without going back and re-reading this thread completely) who has responded has pretty much told you the same thing just not in as many words..
Say what you have to say, people will read it, and be done with it.. no need to keep on just because J&M has an active presence here is simply MY POINT
As for a "patch fix" if you were closer I'd change the darn things for you and you nor HD would ever be the wiser. And then you could move onto another manufacturer for your headset cables.
Did it occur to you that HD is blaming J&M for a manufacturing problem with their connector? Have you spec'd HD' s connector on your bike with others?
I'm not a fan of J&M products generally. But if you are the only guy with the problem, I'm inclined to think the problem is with you.
As an afterthought, I don't know how a person as articulate as you are could say his bike is a Street Glide Ultra Limited when HD never made such a model and it took you a couple of posts to fix your error.
Carl
You don't have a leg to stand on.
J&M has literally sold tens of thousands of cords with this exact same connector and if there were a recurring problem, it would be all over the Internet , which it isn't.
Take your bike to another dealer and tell them that the intercom won't work properly. Let them use their "test" headset and when it doesn't work, they'll fix it and Harley will pay the bill. Who's to say that Harley hasn't changed Vendors (China) and the new connectors aren't problematic?
I'm a leery of your business & motorcycle savvy. For someone who spent $25K or more on a motorcycle and to not know if its a Street glide or an Ultra Classic or a Street glide Ultra (whatever that means) or an Ultra Classic Limited, it sounds like you may have been taken to the cleaners by Your Dealer. I'm sure they will continue to cater to you as long as you're willing to cough up the dough.
