Hooking up ear buds- again?
Old Apr 6, 2013 | 11:19 PM
0ldhippie's Avatar
0ldhippie
Default Hooking up ear buds- again?
OK I took ulta's advise and got a PAC SNI35 rca to speaker wire converter and PolyPlanar Model:IC-3.5PM rca to mini plug adapter to run ear buds off the front speaker wires on my kenwood deck. Hooked it up today and there isn't much volume with the converter turned all the way up? Its turned up into the kenwood's distortion to get good volume??? I'm afraid to just hook both speaker grounds together and go straight into the mini plug for fear of shorting the kenwood amp??? Anybody got a good solution???? Help!! I would really like to try some noise cancelling earbuds for those long highway rides.
Old Apr 8, 2013 | 08:53 AM
UltraNutZ's Avatar
UltraNutZ
ok at least we know it will work cleanly just not a lot of volume correct? you could now add a line driver in the mix Oldhippie.
On a high powered radio, you don't want to connect your ground wires together, you WILL toast your radio outputs.
Old Apr 8, 2013 | 12:47 PM
0ldhippie's Avatar
0ldhippie
Thanks man!!! OK ordered the line driver... Got to bring speaker lines down to preamp then back up for headphones??? I do have unused preamp outs on my JL amp. Would it be better to just use those with the line driver instead of the speaker wires? I hooked them to the earbuds and got almost no volume?? Man this shouldn't be so hard!!!! Does no one hook headphones to their stuff????
Old Apr 8, 2013 | 12:59 PM
UltraNutZ's Avatar
UltraNutZ
OK ordered the line driver... Got to bring speaker lines down to preamp then up for headphones??? Man this shouldn't be so hard!!!! Does no one hook headphones to their stuff????
well in your particular case, instead of it being up then down, it's more about seperating the channels independently then amplifying that signal.
Old Apr 8, 2013 | 02:19 PM
0ldhippie's Avatar
0ldhippie
Thanks! Its kool. I get it.
I did email Kenwood. Their useless reply;
Thank you for contacting Kenwood USA Corporation. We value you as a Kenwood customer and appreciate the opportunity to be of assistance. I understand you are inquiring about the KDC-HD548U. The unit does not support a 3.5 headphone connections. Unfortunately you cannot use ear buds with this unit. Please feel free to contact us again with any additional questions.
Thanks a bunch guys...
robert.schoelkopf@gmail.com
Audio Systems
Oct 30, 2015 10:21 AM
Bagger_Vance
Audio Systems
11
Feb 23, 2015 07:38 AM
scumBAGGER
Dec 24, 2012 12:18 PM
Beans HD
Jun 14, 2011 07:57 AM
WideBoy04
May 13, 2010 01:18 PM
