The Official Poly-Fil Thread
Old Apr 16, 2013 | 12:00 PM
treefiddy's Avatar
treefiddy
Originally Posted by GoPro Steevo
Carl,
Just looking at my bike (or any other batwing), the easiest place for water to get inside the fairing is the spot at the very ends of the windshield, right where the inner and outter meet. In the past, I've thought about a dab of silicone in that spot, but now I'm definitely gonna do it.
But these fairings are not waterproof by any means. Take the cap off your fairing. On the outter, you'll notice a gasket where the fairing meets the windshield. But there's no gasket between the inner fairing and the windshield. And besides, there's only 7 screws holding it all together, and look where the screws are located. Not the best design...
Hey, on this note I just cut up an o-ring of a diameter that pushed in that gap, tapered the end on top to look ok. I too, noticed the likely spot for water to enter there.
Old Apr 16, 2013 | 04:08 PM
Scooby1426's Avatar
Scooby1426
I am looking at buying j & m acoustic pads which are cut for batwing fairings. Suppose to be fire resistance also.
Old Apr 16, 2013 | 04:29 PM
UltraNutZ's Avatar
UltraNutZ
save your $ as they do not help to solidify your bottom end bass. All they simply do is absorb sound waves. You don't want your sound waves absorbed, you want them slowed and then returned in the form of sound pressure to coincide with the movement of the mid bass drivers.
Old Apr 16, 2013 | 07:33 PM
Harleypingman's Avatar
Harleypingman
GoPro, I know perfectly well about inner and outer fairings and gaskets. If you are getting so much water intrusion to soak a syn fiber material, you have a fitment issue between your inner and outer fairings and windshields.
Carl
Old Apr 16, 2013 | 10:51 PM
SweeetHemi's Avatar
SweeetHemi
[ULTRANUTZ>>>>As for the "home-made" comment above. Do your research before you get up here and promote a product which doesn't even come close to doing the same thing polyfil does and you'll find that this has been used in the audio speaker enclosure design process for many a years.. Long before your company ever got into motorcycle amp/speaker setups. Instead of simply saying "hey my product is better and you can buy it here" why don't you enlighten us very specifically as to why you think your product is better. And in fact why you think this product is better than polyfil when even the MASTER engineers of companies such as Klipsch, Steinway, Focal, and Avantgarde all use polyfil and not acoustic foam within their $100k+ speaker enclosures.]
Sorry for the rant...[/quote]
LMAO! I can't wait for the answer to this one!
Old Apr 17, 2013 | 02:00 AM
Mentalmadness's Avatar
Mentalmadness
way to support a paying supporter guys!
Old Apr 17, 2013 | 06:22 AM
UltraNutZ's Avatar
UltraNutZ
Nate, it has nothing to do with paid or unpaid supporters. facts are facts and I think you all know I'm not one to keep my mouth shut..
Old Apr 17, 2013 | 01:44 PM
Mentalmadness
lol while I agree that a review is a review and I would like to know the bad news about something I bought it just seems wrong to knock supporters, But hopefully it is taken in a positive way and then improvements are made from the negative feedback
Old Apr 17, 2013 | 01:56 PM
UltraNutZ's Avatar
UltraNutZ
well John and I go at it from time to time.. he knows it's all in "spirited debate" and nothing personal...
Old Apr 18, 2013 | 12:10 AM
JMJOHN's Avatar
JMJOHN
Sponsor
there are quite a few folks here a lot smarter than I am ,,,
as for improving fairing and/or speaker acoustic properties inside the Harley batwing fairing ,,,,, what I do know is this ,,,,
if you don't do SOMETHING, at high speaker volumes, the lower frequencies will get kind of rumbly or boxy sounding ,,,,,
reducing these unwanted sounds is somewhat easy, making use of acoustic dampening materials either on the back of the speaker, or working as a liner to the inside shell of the fairing ,,,,,,,,
I designed the flame resistant die cut foam pads, as I wanted something that did not absorb water, and no one would have to worry about electrical shorts etc causing a problem inside the fairing ,,,,,,
are there betters ideas out there ?,,,, certainly ,,,,,,,
just remember that the fairing is still open around the fork neck, so no matter what you do, you cannot make it a real efficient speaker acoustic box ,,,,,,,
I think the J&M foam pads provide the best balance of sound improvement with a cost effective, easy to install acoustic material ,,,,,
__________________
JMJOHN,,,, www.Jmcorp.com ,,,, send email direct to John@Jmcorp.com for your HD-Forums VIP Discount Promo Code.
